Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What did you do to your V today?
Old 12-13-2016, 09:57 PM
  #1001
vroom_vroom's Avatar
Well she's back in and the voodoo bearing is on. Wait until tomorrow and see if the *** load of rtv holds. Fingers crossed
Old 12-14-2016, 06:28 AM
  #1002
Tuckin15s's Avatar
Ordered Cradle bushings for my car. Probably gonna drop the rear sub tonight after I pick up a few things in the garage.
Old 12-14-2016, 04:44 PM
  #1003
FuzzyLog1c's Avatar
Extracted V2 subframe bushings to send them off and have 75D poly bushings made.
Old 12-14-2016, 04:47 PM
  #1004
ls1247's Avatar
how did they compare dimensionally with the v1 bushing?
Old 12-14-2016, 09:21 PM
  #1005
FuzzyLog1c's Avatar
They're huge. At least an inch wider and an inch taller.
Old 12-14-2016, 09:30 PM
  #1006
Mercier's Avatar
How big did she think they are?
Old 12-15-2016, 09:33 AM
  #1007
ls1247's Avatar
IIRC, whoever did the v2 cradle swap gained some ride height which might be explained by the taller bushings...could you take a little out of them to lower the car?
Old 12-15-2016, 10:11 AM
  #1008
jmilz28's Avatar
Old 12-15-2016, 03:07 PM
  #1009
FuzzyLog1c's Avatar
The OEM V2 bushing flanges are damn thin. There's no room to compensate for ride height. Better to use coilovers. Or adjustable spring perches.
The height change could've been caused by a couple of things. Newer springs, differences between the V1 and V2 spring perches, or subtle differences in the geometry or thicknesses of the frame elements. Even taking the springs off can cause a temporary boost in ride height until everything settles again.
Even if room was available, I don't think it's a good idea to adjust for ride height using bushings. You want a certain flange height to isolate the subframe from the car body. Anyone in the market for bushings should be looking to replace the OEM progressive springs, so I don't see the ride height concern as significant. The significant concern is the effect on driveline misalignment angles.
Old 12-15-2016, 05:04 PM
  #1010
ls1247's Avatar
Understood but it never hurts to look for the low hanging fruit. You doing a v2 cradle swap? Though you had the gforce 9 inch.
Old 12-15-2016, 07:43 PM
  #1011
FuzzyLog1c's Avatar
Yep, and I'm ordering their V2 housing to replace my V1 housing with. The guts are the same.
V2:
V2 side view showing rear bushing:
V1:
The axles are slightly different length but Chris and I will work through that. I might pick up a set of 33 spline outer stubs too, depending on how much they want for them. Right now SKF sells 5x115 X-Tracker wheel bearings in both 30 and 33 spline variants, but who knows how long they'll continue selling the 30 spline version given the lack of customers. The only thing that sucks is that the 33 spline wheel bearings are twice the price. I've never heard of a Corvette tax before, but who knows.
Old 12-15-2016, 07:52 PM
  #1012
ls1247's Avatar
Awesome....You mind posting this in the original V2 cradle swap thread?
https://ls1tech.com/forums/cadillac-...rame-swap.html
You doing the fuel tank swap too????
Old 12-15-2016, 07:59 PM
  #1013
FuzzyLog1c's Avatar
Yep. Just working on adapting the wiring harness, since my DW300 bulkhead connectors are similar but not quite exactly the same. So close to a direct fit.
Old 12-15-2016, 08:05 PM
  #1014
ls1247's Avatar
Thought I heard on here that the V2 tank and the standard CTS tank were different due to differences in the e-brake setup....which one you using?
Old 12-15-2016, 09:02 PM
  #1015
FuzzyLog1c's Avatar
The sedan, coupe, wagon, and V all use the same part number on the tank. There is approximately 80% commonality with all of the other components. The big difference is that the V version has a better pump module.
Old 12-15-2016, 10:05 PM
  #1016
TorchRedRob's Avatar
Can't wait to see the details on this tank. I'm sure I'll follow suit. Thanks for pioneering, man!
Old 12-16-2016, 09:01 AM
  #1017
ls1247's Avatar
Any info you care to share would be much appreciated!
Old 12-19-2016, 01:33 PM
  #1018
BudRacing's Avatar
I replaced a worn wheel bearing and reapplied the top windshield molding where about 12" had popped up.
I had to swap the lug studs out from my old bearing to new since I have longer studs. I ended up running over to Harbor Freight, which is a convenient 5 minutes away from my house, and bought a 6 ton A-Frame Bench Shop Press (aka, bottle jack in an A-frame). Well worth the investment, and still cheaper than having a shop do the work. The press is far from perfect and it's a bit awkward fitting the items to be pressed within its platform and blocks, but with some creativity can work.
The windshield molding was pretty simple and the adhesive cost me $7. Pulled the whole strip out, cleaned the crevice and the removed molding with windex and a couple rags, applied a new bead on top of the old dried up bead, another bead on the backside of the molding, let it tack up, reapplied and smoothed with a plastic putty spatula and held down the trouble areas for a few minutes until the adhesive had set enough. In hindsight it probably would have been best to heat the molding a bit to soften it, but it ended up working fine without that step. It was 60*+ in my garage.
It felt good finally knocking some maintenance items off the checklist.
Old 12-25-2016, 11:19 AM
  #1019
CTS-V Shifter Sales
07CTS-V's Avatar
Old 12-25-2016, 11:40 AM
  #1020
With the hood still on, so you do like a challenge!
Quick Reply: What did you do to your V today?
