Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What did you do to your V today?
Old 01-17-2017, 07:50 AM
  #1061
WS6WRX's Avatar
Originally Posted by Tuckin15s
You can build the head of the bolt up with weld then weld a nut to it, just get it really hot and rapid cool it with some penetrating oil. Because the head is aluminium the weld will not stick to it. I have to do exhaust manifold bolts weekly on Silverado and sierras so I have learned a few tricks vs pulling the entire head to have a machine shop remove it.
Yea, I tried that for a couple hours on Sunday. Between my less than stellar welding skills, cheap flux core mig and cramped access to the sunken bolt, I wasn't able to make it happen.
Old 01-17-2017, 10:18 AM
  #1062
BudRacing's Avatar
When I had a broken bolt on the rear PS head I ended up pulling both heads and doing a $500 top end rebuild. In retrospect, I'm kinda glad I did as it gave me some peace of mind and got me more familiar with the internals of small blocks (they're very simple). However, it was definitely a pain in the ***.
Old 01-17-2017, 10:30 AM
  #1063
Tuckin15s's Avatar
Word, can't win them all. I spent 6 hours on a rear one on a 2500hd once, I got it. Told myself I would never spend that amount of time on one again though. haha
Old 01-19-2017, 11:05 AM
  #1064
BudRacing's Avatar
I wrapped up a few overdue maintenance items last night. Voodoo driveshaft, OEM coupler replaced, CS toe rods, Mevotech rear upper control arms.
The upper control arms really had a minimal effect, but the toe rods are much more firm. The squishy rubber bushings in the OE toe rods did not play well with the 95a trailing arm bushings. I was getting a squirly feeling from the rear in a straight line. That is now gone. I matched the new toe rods to the old rods to maintain the alignment. Just stuck the bolts through both rods at the same time while I had them laying on the floor and adjusted them accordingly. I'll probably have it checked again before I replace the rear tires, but it seems to be right on.
The Voodoo driveshaft is everything it claims to be. Glad I don't have to deal with an aftermarket unit and the troubles others have experienced at twice the cost.
Old 01-21-2017, 01:58 PM
  #1065
WS6WRX's Avatar
Made a sound clip today.
Old 01-21-2017, 06:18 PM
  #1066
Doble's Avatar
Old 01-21-2017, 09:48 PM
  #1067
PLA TME's Avatar
Where did you install the cutouts? Just in front of the mufflers?
Old 01-22-2017, 12:11 AM
  #1068
vroom_vroom's Avatar
Got all my goodies ordered today, OBD, high flows, header wrap, arp.
Get my tune lined up next week and we can put another chapter of the v to bed
Old 01-23-2017, 07:05 AM
  #1069
WS6WRX's Avatar
Yep, just after the bend in the pipe coming from the center of the car, right before the OEM mufflers and angled down just a tad so they aren't pointed straight at the spare tire tub.
Stays quiet when I want and loud when I like it.
Old 01-23-2017, 02:28 PM
  #1070
Spent the morning being a copy cat........
Center section of the wheel turned out stellar, now time to re wrap it.
Attached Thumbnails What did you do to your V today?-photo484.jpg   What did you do to your V today?-photo816.jpg
Old 01-23-2017, 09:23 PM
  #1071
jcollege's Avatar
That wheel looks great, almost tempting me to do mine.
Old 01-24-2017, 06:23 AM
  #1072
Tuckin15s's Avatar
I have been wanting to do this for some time!
Old 01-24-2017, 08:06 AM
  #1073
Constant hair dryer and keep pulling and it turns out pretty sweet.
Old 01-24-2017, 01:07 PM
  #1074
Tuckin15s's Avatar
Word, I have done it on a vehicle I had in the past. Did you use the Di Noc 3m stuff?
Old 01-24-2017, 02:31 PM
  #1075
Nothing fancy, just what I found on amazon
TCBunny 3D Carbon Fiber Vinyl Film Wrap Black 12" x 60" Sheet https://www.amazon.com/dp/B0059XCVVO..._wK7HybQEDEFQN
Old 01-24-2017, 02:33 PM
  #1076
svnmpwr's Avatar
broke a driver side half shaft on my 04 V, anyone have an 06-07 driver side half shaft?
  #1077
jcollege's Avatar
Bought some diff fluid, tranny fluid, oil and filter, hoping to get all of that tackled this weekend.
Old 01-24-2017, 03:05 PM
  #1078
Choppy_Idle's Avatar
Here the same, I also swapped to the 06-07 halfshafts and some other mods, I will show next time, what did you think was the reason for broking, wheelhop?
Regards
Ronald
Old 01-24-2017, 03:23 PM
  #1079
svnmpwr's Avatar
Regards
Ronald
I have all the CS bushings& mounts, still wheel hops. broke a dif once already, replaced with later model srx 3.90 ratio. Since the driver side CV broke, going to try a bigger shaft on one side to counter the wheel hop.
Old 01-24-2017, 04:28 PM
  #1080
100% the same way I go now with my car, but I will try to use the LS2 shafts on both sides, not only driver side and will upgrade the lsd with more preload or more discs inside!
You have looked into the lsd, I have broken preload washer from clutches inside, then you only have 1 wheel spinning at burn out?!
Regards
Ronald
Quick Reply: What did you do to your V today?
