Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
loud wine in 1st and second after trans insert
Old 12-14-2013, 08:36 PM
rbsurfer's Avatar
Default loud wine in 1st and second after trans insert
Well I installed the Revshift trans insert and now decelerating in 1st and 2nd it wines like the diff and 2nd 3rd 4th are hard to get into?? And idea guys??
Old 12-14-2013, 08:43 PM
MichaelSuch's Avatar
Have you replaced the motor mounts as well? If the motor mounts failed, which I can guarantee they have if they haven't been replaced with an aftermarket, and a new trans insert is installed you will have problems getting into other gears. The linkage is probably in a slight bind due to the improper angle of the transmission now.
Old 12-14-2013, 09:24 PM
rbsurfer's Avatar
I have mount just no time today already did subframe and diff and trailing are
Old 12-14-2013, 09:30 PM
Put the motor mounts in and report back.
Old 12-14-2013, 09:43 PM
rbsurfer's Avatar
Will do
Old 12-15-2013, 04:34 PM
bmylez's Avatar
Is the wine at least a Cabernet.
Old 12-15-2013, 04:54 PM
Fweasel's Avatar
Definitely hold all judgement until the motor mounts are in, but many have reported some additional noise with the RevShift insert that subsides after a short break in period. I noticed no additional noise after installing mine.
Old 12-15-2013, 06:26 PM
jenks40's Avatar
Ha! It's a merlot. At least you to know somebody here knows how to spell...
Old 12-17-2013, 10:21 PM
rbsurfer's Avatar
Got the motor mounts in and everything is greatt
Old 12-18-2013, 09:56 AM
Fweasel's Avatar
Good to hear. I couldn't believe how much quieter things got after I replaced the motor mounts.
Old 12-18-2013, 10:16 AM
thousherlock's Avatar
God I hope this is the case for me. I installed the creative steel trans mount and it vibrates like sum b!..ch now. gonna do cradle, motor mounts, and dif ASAP.
Old 12-18-2013, 02:34 PM
Creative Steel's Avatar
I'll bet/hope that new motor mounts will fix the vibrations. Are the motor mounts that you have now the blown stock units? If so, the engine is basically sitting on the sub-frame....metal to metal.
Our trans mount is the softest trans mount on the market. Built specifically NOT to transmit vibrations. Since the trans mount is not a "moving part", it can't cause the vibration, but now that the rear of the trans is at the proper height I wonder, that since the motor mounts are not holding the engine at the proper height your drive line is now out of alignment causing the vibes ????
Motor mounts and trans mounts are usually installed at the same time. I wonder if this is why we don't hear of this often enough to have an answer already figured out.
Install the motor mounts and report back
Quick Reply: loud wine in 1st and second after trans insert
