Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
help ... I have no heat. Heater blows Ice cold air.
Old 01-02-2014, 09:30 AM
Sweetwilliebrownjr's Avatar
I'm assuming the tech was seeing if the actuator for the temp door was working. It could be that the actuator is working, but the door itself isn't moving. If the door was broken, it may not move, but would allow the actuator to move. That's the only thing I can think of that would allow it to blow cold when all the way on hot. Any other possibility would either have the actuator not working, or it would at least blow warm air.
Old 01-02-2014, 02:32 PM
69stangscj's Avatar
If the door wasn’t moving but the servo motor was, meaning a broken door wouldn’t there be a code in the HVAC system?
Old 01-02-2014, 03:09 PM
The computer reads the position of the actuator, not the door, so it prolly wouldn't throw a code unless the door was binding the actuator somehow.
Old 01-02-2014, 04:12 PM
69stangscj's Avatar
I thought they would spin past the stop with a broken door and give a code?
Old 01-02-2014, 05:05 PM
It can, but I can't come up with a scenario in my head where it blows ice cold air out the vents, but the actuator is actually working. On some actuators, there are linkages and pivots and such, that could possibly keep it from overextending itself. I have no idea if our cars have them, because I've never had to go into one of these dashes yet.
Old 01-02-2014, 06:04 PM
69stangscj's Avatar
I haven't been into these cars either, but I've fixed other cars with broken blend doors. The motor would work but the broken blend door would be stuck on cold or hot.
Old 06-12-2014, 04:09 PM
davis.doug's Avatar
i bought the cts-v from nesluopetan, just drove it from utah to north carolina with no problems. when i got home i noticed the passager side floor was soaked could this have anything to do with the heater not working? it also rained pretty hard on my way home to so maybe that has something to do with it
Old 06-12-2014, 04:28 PM
tmonttt's Avatar
If the passenger floorboard is soaked, then IIRC it's a problem with the heater core that sits right there.
I'm sure someone else will chime in about it.
Old 06-12-2014, 05:14 PM
davis.doug's Avatar
im thinking it most likely the heater core too, just looking for other opinions before i pull the dash apart
Old 06-12-2014, 05:19 PM
ls1247's Avatar
Didn't say if it was antifreeze or just water on the floor. if its water its probably a clogged sunroof drain or hvac drain or even a bad door seal. Usually when a heater core starts leaking the windshield will fog up on defrost and you'll smell antifreeze. Good luck!
Old 06-12-2014, 08:00 PM
davis.doug's Avatar
Its water on the floor. Thanks im gonna look into it tomorrow. Is there any write ups on the sun roof drain tubes
Old 06-13-2014, 09:13 AM
  #32
ls1247's Avatar
http://www.cadillacforums.com/forums...lease-help.htm
http://www.cadillacforums.com/forums...-tip-help.html
Old 06-13-2014, 09:21 AM
  #33
davis.doug's Avatar
thank you
Old 06-13-2014, 10:12 AM
  #34
voodoochikin04's Avatar
Just to put in my experiences... both of my cars...base cts and V... had heat issues. The heat was ice cold on the driver side and very very mild on the passenger side.. both cars were resolved with a heater core flush.
to me, if all the doors are working, the inlet and outlet lines are hot, and yet no warm air.... sounds like the core is plugged up and water is coming in and right back out without going through the entire heater core.
Old 10-20-2016, 06:26 PM
  #35
Bobzurunkle's Avatar
There's a few chapters missing here. I have '10 DTS with similar heater issue. Did Nate ever find a fix? Sounds like he just sold the problem to Doug. Did Doug find the real problem cause? Getting my thermostat changed tomorrow along with a core flush and I'll throw in a coolant change to cover some of the possible causes mentioned in this great, if inconclusive thread. Loved all the inputs, made for an interesting read, back soon.
Old 11-29-2016, 09:24 PM
  #36
ZeeBob's Avatar
Hey, so it took awhile.. wanted to be sure I had it fixed before giving a followup.... had the heater core flushed and changed the engine thermostat and I've had no problems since. If problem reoccurs in the future I'll let you know. Maybe my case was different though, right? but it sounded the same.
Old 11-30-2016, 08:42 PM
  #37
4doortypels's Avatar
Blend door actuator?
Quick Reply: help ... I have no heat. Heater blows Ice cold air.
