Lower steering shaft removal help
if I remember the piece is just like an air compressor hose and connecter in regards to connecting and disconnecting it. it's been years but I remember being on my back for hours with the driver seat declined fully... take a pick for me so I can remember.. Btw, I remember also rigging a speaker gauge wire to hold the piece in place while did it but I don't remember if it was during disconnect or reconnect..
It's pretty simple. Two bolts.. One at the rack and one at the half shaft (that most have to dent for header clearance. It's collapse able so start at the mid shaft bolt and get that out then knock it down and off the upper half shaft. Then unbolt the bottom at the rack and snake it out.
You have to fully remove the bolt, there is a notch that the bolt holds onto. You will need to remove the upper bolt and slide the sleeve upwards to give you the space to properly remove the lower half from the steerin rack..
You will have cramps in your hands from doin so
