Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
04 Gen lll ls1+t56 into 05 cts. need wiring help!
Old 05-17-2014, 10:25 PM
cts v wanna b's Avatar
Default 04 Gen lll ls1+t56 into 05 cts. need wiring help!
Determined to figure it out just need guidance to integrate the engine into the car. I realize it's not practical but neither is buying a v when you don't have the $$$$$. Any ideas are greatly appreciated. Thanks!
Old 05-18-2014, 06:51 AM
bigassogre's Avatar
What do u need help with? Im not sure what will and wont work since so much info is transferred via serial data
Old 05-18-2014, 09:18 AM
jerrad's Avatar
I have zero knowledge as far as what goes into it.
I can say that there was a guy in Dallas that swapped in a ls1/t56 into an 03 cts, I saw it on craigslist about a year ago.
Old 05-18-2014, 01:06 PM
brack86svo's Avatar
What is the ecu that you are going to use out of?
Old 05-18-2014, 01:07 PM
CTS-V Shifter Sales
07CTS-V's Avatar
Sell the car and spend $10k on a real V. It'll be worth the savings in headaches.
Old 05-18-2014, 01:58 PM
actrite80's Avatar
True that
Old 05-18-2014, 04:44 PM
Fweasel's Avatar
Originally Posted by actrite80
True dat
fixed
Old 05-18-2014, 06:21 PM
ryridesmotox's Avatar
Didn't someone tty to accomplish this a while back? The dash and traction control stuff didn't work properly or something. I can't remember what forum it was on, here or one of the other ones.
Old 05-19-2014, 03:18 PM
it's off a 04 Pontiac gto
Old 05-19-2014, 03:25 PM
NIKDSC5's Avatar
Well, at least he got his name right!
Old 05-19-2014, 03:28 PM
brack86svo's Avatar
Your best and most likely bet would be to source a 04-05 cts v ecu and engine harness. Buy a tuning software and put the all the tuning info in to match the ls1 - VE tables, MAF tables, etc... And hope for the best. At least that would give you a better head start. You may also have to have other computers in the car programmed to match the ecu.
The headache involved in doing this and making it function with the car as if it was stock, is probably not worth the time and trouble. Making it work in a standalone sense, with aftermarket gauges and just driveable, probably wouldn't be to bad, with the right knowledge of all the electrical systems in the car.
Old 05-20-2014, 10:38 AM
thanks that pretty much sums up what I need to know. Now... how do I wire the harness so it will work as a standalone?
Old 05-20-2014, 05:07 PM
voodoochikin04's Avatar
get a stand alone harness from a supplier for LS harnesses... none of your dash or gauges are gonna work from the stock setup.
you could get the complete engine harness, interior harness, dash, gauges, stereo, and clutch setup from a salvaged V... and end up blowing your brains out trying to get the harnesses installed... idk man, its sooooo much more trouble than its worth. just sell everything youve accquired and look for a wrecked V that need body work... ive seen them selling under $8,000. Youd be so much further ahead. This has been tried and it never seems to work out right. good luck
Old 05-20-2014, 05:09 PM
kyle242gt's Avatar
Wasn't there some goober that used a carb?
Old 05-20-2014, 05:35 PM
brack86svo's Avatar
Get a wiring diagram from the donor vehicle. Find what inputs you need, and don't. You will need to make changes to the ecu for things you need, and do not.
There are companies out there, that will take your ecu and harness and make it a standalone system, label everything and make it plug and play. This will merely get you running with basic inputs, such as battery and ignition.
Old 05-20-2014, 05:48 PM
steves ls6's Avatar
I don't understand why this would be so difficult. Look what this guy did. I saw this car 10 years ago on the dragstrip.
http://www.gmhightechperformance.com...cts_b_feature/
Old 05-21-2014, 05:21 PM
liqidvenom's Avatar
I would think if he used a cts-v harness and ecu, this would be no different than swapping a different engine into a V.
Is y our cts already manual? if so that would make this job easier. I would think the data would be read from the harness in a similar fashion.
Old 05-21-2014, 05:26 PM
liqidvenom's Avatar
This is basically it, but with the v8 harness. And use HPtuners to turn off any MILs that appear for things you dont need.
And this car is faster than 99.9999% of all v1's so this is all good by me.
Old 05-21-2014, 10:43 PM
I am under the impression that a cts-v ecu will physically not plug into the base CTS harness
.. .???? And that they are not even located in the same places. So it wouldn't be as easy as and engine and ecu swap with turning off unneeded items.
Quick Reply: 04 Gen lll ls1+t56 into 05 cts. need wiring help!
