Maggie Injectors?
Maggie Injectors?
Anyone care to share what size injectors come with the Maggie.
Mine have a blue ring near the top and are labeled c132a02761.
I did a search and the number comes up with no results.
I appreciate the help.
Thanks men.
My tuner was having some issues between the injectors and the magnavolt.
As soon as I'd go into boost the magnavolt would add fuel and he was having an issue leaning the car out a little.
If you have the stock Maggie tune, the injector tables for the 60# are way off. You would need the Banish data for the injectors to get them set right. Magnacharger half asses the tune, to say the least.
In the hp tuner program the tuner went to a tab that allows you to add fuel while in boost (Cant remember the name) and had to take it down to nearly zero.
Green=42 blue=60. Unless your running an SD tune there is no way your tuner is adding fuel by boost. If your running the MAF then your talking power enrichment. Try the banish data for those 60's. I was almost maxing the maf with the 112 the way I had it and it would throw off the the tune as the maf was going ape **** and the magnavolt was adding fuel as soon as boost would come in. Hence why I'm going SD and tuning for actual boost
To get the fuel right he had to tell the computer than the injectors were 50# or 52#, I can't remember.
Also, the duty cycle is less than 50%.
Mine has the Mototron S107. http://www.bmotorsports.com/shop/pro...roducts_id/449
Has he entered the correct data for the MAP you are running? Even if your fuel pressure rises with the magnavolt it shouldn't bring the AFR in the 8's unless your pressure is way up there. I'd hook up a pressure gauge off the rail and tape it to the windshield so u can watch it while street tuning. Might help
When I had mine tuned, the tuner had to do the same thing due to the injector data being so far off. You really are going to have to get the Banish data for the 60lbers to do a good SD tune, or your tuner will struggle to get it right. The data really isn't out there other than in his injector CD. With his data, I was able to actually set the ecm to the right size injectors and begin to get accurate data for the VE table.
The magnavolt is making me nervous.
I'm thinking about swapping in a dw300 with a hotwire kit and removing the magnavolt.
I assume that would work, is there any reason it shouldn't?
I know on my old turbo buick I had a FP regulator that increase pressure with vacuum.
A PD blower is about the easiest thing to tune aside from N/A. If he can't get the tune correct with a predictable setup such as a PD blower you need to reconsider the person doing your tune.
I knew the answers to many of these problems before I attempted my first tune. I'd be looking for another tuner, or get the hardware and learn yourself.
CTS-V Shifter Sales
