V2 S/C on our V1's?
V2 S/C on our V1's?
I am going to do a search but I am on a short suspense here so any help will be appreciated. I have a chance to pick up a complete stock V2 S/C system for around a grand. I know I am going to have to run LS3 heads which isn't a problem. I was going to do H/C soon anyway. I need to know what else I will have to modify to make it fit my 07'. I guess the main concerns are pulley alignment, strut tower brace and hood clearance, heat exchanger and pump mounting, injector harness compatibility, fuel line inlet location, PCV, and I am sure there is a bunch more.
Thanks.
Thanks.
Thanks.
Thanks.
Biggest problem you'll have is the belt routing for the supercharger. There is less room between the crank and the radiator and ABS module on the V1, so the second belt system isn't likely to fit without a lot of work.
Is like to see how it fits though. Go ahead, be the first.
For 1000$,I think you should take it and start mocking it up. Before you buy heads you will know if it is too big a hassle or not. If anything im sure you could get more than a grand for it
There's definitely a reason all the blowers run on the serpentine line for these cars... We got shafted on space and can't really do it the "right" way and run the blower on its own
I was not aware the V2 ran it's own belt system or additional belt system. I took a quick look at a buddy's V2 the other day and noticed the belt was an 8 rib but I just figured they ran all the accessories that way too. He didn't look like he had any more room in the front of his motor then we do though. But I guess they spaced the motor back some or redesigned the chassis.
So the consensus is that there would be a bunch of redesign to make it work? If that is agreed on then I am going to pass.
It's never been done as far as I know. The V2 has the 6 rib accessory belt and then the 8 rib SC belt out in front of that. With the fans and ABS module so close to the motor, I don't know that it'd fit. Moving the Rad forward is not too hard, however the ABS module is a little more work.
The E-Force is a lot less than you think, it can be had for just under half of what you see them listed for, which makes it a bargain. And with the right HE. And pump, we're seeing about 10* above ambient IAT's which is unheard of for any other supercharger.
DMM, when you can say that the E-force can be had for less than half of what they are listed for, can you elaborate? I see them around the $6,000 mark, but if I could be into one for half of that + whatever I have to fab, I'd be in.
I went back through your build thread, but wasn't able to find the parts list you put together. Any chance of linking me to it or possibly PM me about what you have into the E-force setup.
I know we are a sponsor on CF and a couple other sites but not sure about this one so I won't mention the company but I don't think we are direct with Edelbrock yet. I know a few of our affiliates are, so getting the parts won't be an issue. The guy selling the 1900 is a good customer of ours so I will pass on it for now so he can get rid of it. I will keep the E-Force in mind.
I still need to do all the stock upgrade stuff to the V anyway. I think I am going to clean out CS for suspension and bushing stuff, get 07's Hurst shifter, OBX catted 1 7/8" headers, Racelund dual 3" cut out's, complete LS7 clutch kit with slave and Tick's bleeder, make my own adjustable Master like I do with Vettes, and finish up my custom CAI. I still need to finish the box and ram air portion and convert over to the LS7 MAF card I have. I have already swapped the normal stuff like plugs, wires, 160* T-Stat' made an actual functioning PCV system and put a street tune on it. I have a cam spec'd and I am thinking about yanking the heads off and porting them with the same measurements I used when I ported my TBSS heads. I like to do that to check the short and clean it out. It also allows me to put in new lifters. That should put me in the 480rw range. That will tide me over till next year when I can get serious with this thing.
Thanks for all the help, you guys are great. Once I get everything dialed in I will start offering different packages for our cars.
https://ls1tech.com/forums/cadillac-cts-v/1700225-whipple-off-rethinking-my-next-option.html
