05 cts-v build
05 cts-v build
JUST JOINED
05cts-v
so i have a blown ls6
*broken pistons
*no damage to the block
everything else is fine
im not looking to boost or anything
Iv been told about 3 types builds..build the ls6..lq4 with my cam and heads...ls9 and squeezz..ls3...ect ect
im looking to reuse my heads, manifold,cams ect...if i find another block
iv heard good things about the lq4 and lq9 about how they can take a beating
and then again a ls3 sounds nice as well.
so pretty much im looking for as much info as i can to make up my mind and what would be best to build
"build" as your wondering of how big i wanna go...well i was happy with the 389hp it was putting out when it ran..so im not looking for crazy 700+ hp ha
maybe a cool 500hp at the most would be nice.
as for budget...im maxing out at 3k....
i have a t56 tans if that helps with answers...
sooo what should i do...rebuild the ls6...or look for another block and just put it back together.
located in Southern California for any blocks for sell
05cts-v
*broken pistons
I'm will track this thread. I wanna see more options. I can flex a little more than 3k. but max at 5-5500. I'd love 550 HP or so.
on my LS6, would some AFR heads get me there? and a cam ofcourse.
sorry guys i forgot to mention i will be going all the work my self so by all means the 3k is going to parts only
sorry guys i forgot to mention i will be doing all the work my self so by all means the 3k is going to parts only
alright then sounds good.
now what piston combo do you think i should go with ?
im not to familiar with reliable brands and compression ratios..
like i said im not looking for anything crazy, it will still by my daily driver with a punch .
btw thanks alot for the help
$3k is not going to get you there. I'd get the best shortblock I could find lq4,lm7,ls1,ls2,ls3,etc and install a decent cam and have your heads cleaned up. After lifters, push rods, gaskets, motor mounts, you'll be out of money.
Keep in mind you'll need abou $500 for a tune no matter what you do unless you go back stock displacement.
Cathedral heads will work on an LS3/L92 but knock sensors are different and a PITA.
For 3k..assuming you are doing the labor you will be stuck to finding a stock ls1/6 shortblock. I wouldn't put a stock lq motor in it just because you are adding weight and not really gaining anything other then that.
ls1 and ls6 shortblocks are basically identical(year dependant).
oo i see , thanks ..now for sure the lq is out of the equation...
i just have had a good sours for engines down here in california..im dry out of links . help?
Ls6 will be fine on an ls3... but ported ls6 on an ls3 would rock too. Built short block stroker would be ideal... 243 heads should fit every ls motor... minimum bore sizing isnt gonna work. Ls3 take no less than a 4 inch bore... ls7 take 4.100 bore minimum. Personally id do an iron 404 to 408 with your ls6 heads ported... or 383 with ported ls6. Stock ls3 on a 408 would be nice since you can get a few bux back for ls6 cam intake and tb. Take in that ls3 is a gen 4 set up...so harness and sensors etc change...
Me stock ls3 heads l76 intake car style lq 408... 408 will help deshroud the valves... lq gen 3 block would retain all sensors covers and harness... all will cost close to the same to do... so make the most power
soooooooo
*stick with a LS engine
*rebuild
*tune
oooooor
*buy a short block ls6 or 2
and just put it back together?
as for the build my question is what brand and combo of pistons should i go with?
*rebuild
*tune
oooooor
