Forgestar CF5 fit V1 after 5-lug conversion?
I'm planning a 5-lug conversion of my 2006 CTS-V, using a C6 hub and keeping the stock calipers. Can anyone tell me if the Forgestar CF5's will fit after the conversion? I've read that a lot of wheels don't have enough clearance for the calipers.
i just found them. i've seen them in the past so i knew they existed.
i'll probably have to track them down again once i start looking for wheels next spring when i do my 5 lug swap.
i would make sure you get the wheel offset correct. I had too much positive offset that i had to use spacers to help the wheels fit. The front spindle and rear tub were my issues. Never had a caliper issue except on my Tahoe where i had front and rear 380mm rotors with 6-piston front and 4 piston rear calipers. Needed a 20mm front spacer and custom studs for that project.
Zr1 wheels you will need a 8mm front spacer to correct the offset and a 25mm rear spacer to bring the wheel out properly...
