Leaking radiator or hose?
Hey guys, it´s me again!
New pain is a leaking rad or hose, i hoped it was the hose and put on a new hose clamp, but that wasn´t the issue, fluid will only come out at full pull, while i´m on crusing, there was no discharge, please look at the pics below and gave me your experiences...
Best regards,
Ronald
Best regards,
Ronald
Radiator. As mentioned, get the alradco radiator and be done, because if you do get a factory replacement, you will be replacing it again. I went the cheap route and bought a factory radiator with a lifetime warranty. It split 2500 miles later, so I bought the alradco one. I rather just be done with it instead of planning a radiator swap every oil change.
