What to do with 12k on my First Gen V...
I already have the following parts
-Corsa Catback Exhaust
-K&N Intake
-CS Subframe/Transmission Bushings/Motor Mounts
-Hurst Short Shifter
I was thinking the following
-CS Rear End + CF Driveshaft - 5,175
-FAST Intake Manifold + LS2 TB - 1,350
-Kooks Headers + High Flow Cats - 1,350
-Tune - 650
-Installation of new Parts ??? - 2,500 ???
Grand Total - 11,025
Im not really thinking about taxes here either - so the Rear may be closer to 6k etc which would put me pretty close to 12k if the rest of the mod and install prices are on point.
I want to keep the car NA, hence no Maggie on this list. Just want to make it a fun quick street car that I dont have to worry about blowing up the motor or rear on (knock on wood) I was also thinking of going 4.10 on the Gear Ratio, but should do more research. Also - I think the clutch should hold up fine (car has under 60k miles) but once I do a cam, should probably think about changing that up as well.
Thanks
-K&N Intake
-Tune - 650
Thanks
I didn't have much luck with the cf one piece. The cv joints gave up after 15k miles. Go with the voodoochikn rebuild and the CS adapter and pocket that grand.
If you don't plan on spending any time over 150mph, the 410s would be awesome I think. 1st would be a launch only gear, you wouldn't even use it around town which I only do now about half the time with the 373s. I live in a hilly area and 410s would work a little better on the interstates around here with all the truck traffic. 6th is a little tall below 65 if you're pulling a hill.
Good luck with the build.
Also, most states don't tax mail order stuff... Least of all Oregon. Creative steel is in Salem, Oregon... Oregon doesn't have sales tax at all.
And getting the gen4 block assumes you're 04-05. An LS2 is a gen4 block and you can get rectangular port heads for them. LS3 heads are the bee's knees
Thanks for the input so far guys, greatly appreciated
-Unfortunately I think the V2 scenario is just too many moving parts that would be out of my control / I dont want to deal with haha.
- I really really love my car, im fine with some of the limitations that come with it, I just want to pep her up, primarily so my friend with his Boss 302 cant slap me around (we havent run yet) and so I can give my co-workers Bolt on B8 S4 a run for his money
- Good to know about the CF Driveshaft, will not mind saving the 1k. I guess im just a sucker for Lightweight parts
-Are KDubs Kooks headers? or Coil overs?
- Ive looked through alternate power plants and 4k is always the goal number, but never the real one. If you can show me the math and source of vendors that fall into those numbers, That is def a route I would pursue.
Again, thank you very much guys. I just want to make sure im investing this money in the best places (besides upgrading to the v2 )
Also, he said HCI for $4k, so he means keep your current motor, get some badass heads, a fat cam, and a FAST intake, or maybe that new MSD Atomic Airforce intake, and let her eat.
If you are getting the CS 8.8, I agree, don't bother with aftermarket driveshafts. Get the Voodoochikin carrier bearing upgrade like others and I have, and use the CS stock adapter.
Also, get the LS9x clutch along with philistine's master cylinder upgrade and your car will be easy to drive, shift like butter, and hold all the power in the world. I wish I had done it to begin with, but whatever.
Your car will "still be a V1" as the V2 owners say, but it will be pretty f'ing nasty and hold its own.
KW coilovers are "kdubs".
The bushings/rear/headers however I'm not messing with on my own
Cars make me happy, totally understand the lack of return when it comes to investment in aftermarket parts though. Buuuuuut im gonna do it anyway
Headers aren't bad at all as long as you spray the **** out of the bolts with PB Blaster for a couple days in a row, which sounds like you can do with it sitting in a garage all the time. You can do mounts at the same time you do those, so it's 2 birds with 1 stone. Subframe bushings suck, but also not super horrible. So far my toughest project on this car has been cam swap and clutch swap. The 8.8 swap sounds daunting, but that also is a bolt-in affair with no special tools needed, but it definitely will take a whole day.
