Accidentally finding 1st instead of 3rd
TWICE!!!... an was like.. Mother effer!! Once was running a 600hp blown GTO that I knew would smoke me... I was at redline in second and slammed that baby into first.. tires just squealled and slid... car didnt really over rev much.
Then I did it running a 300c srt8... same ordeal. Both times trans seemed ok afterwords.. I did have to go home and repair my pride.. O.o
I would think that would be pretty hard to do based on the shift pattern and feel. 1st is way on the left and 3rd feels right in the middle. Once im going a decent speed it seems rather difficult to put back into 1st.
I've gone into 4th instead of 6th a few times. Probably new bushings are needed.
Mine happened with the 1st gen Katech shifter that was in my car.. it wasnt much better than a stock shifter... kinda sloppy as well. When adreneline is pumping and you go to slam up from second, my Mr.Flash speed shifts shot that sucker right into firrst!! ya know, cant get into first gear while sitting at a stop light half the time BUT it will slide right in at redline from a higher gear.. stupid lol. Hasnt even come close with my hurst unit.
BMWs have had similar issue in the past, where engine/trans mounts are in bad shape, under load torque the trans will twist or move some, then during the shift (clutching) the trans unloads and the driver will find himself banging the wrong gear. A friend did that on his E36 M3 at the strip, and bent most of his exhaust valves.
