Cat question
Cat question
I have an 07 Ctsv with long tubes and magnaflow. It currently has no cats and won't pass inspection. Can I buy 2 high flow cats and have them installed or do I need to buy the whole piece that bolts to the headers with cats already in them? What size cats would I need and where is a cheap place to get them online?
Welcome to modified exhaust nightmare #1.
There are no listed cat replacements for the V1.
I had to roll the dice and spent $1500.00 for stainless pipes (B&B) to be modified with cats for and Escalade (same displacement) as the cats supplied from B&B won't pass in CA.
The exhaust guy flat out told me that if it didn't pass, TOO BAD!
The good news is that the emissions are in the mud.
The bad news is that it won't pass visual, because the cats are not listed as being for a CTS-V.
I figure that if I have to go to an arbitrator (they have those in Calif just for this ****) I will pass as I have good intentions.
No sniffer, just an OBD2 and it has been tuned so no lights. I think it will pass as long as it has cats on it. I found some magnaflow high flow cats 3" in and out for like 80 each on eBay. I think I am going to try them.
heavymetals, I think that you might be in error somewhat if you are talking 2000 & newer vehicles.
OBDI II requires Computer verification, and I don't think that you are allowed any fails or opens, visual, & the technician can sniff at his discretion.
This is what I believe to be correct.
I have owned like 8 performance cars without cats and never failed maryland emissions. 99.9% of the workers never actually look for them. This goes for my brother and countless friends as well.
If it is a state inspection to be able to get tags you will fail though because the car goes on a lift.
If you are talking about emissions run it through and i bet itll pass if it doesnt have a check engine light.
An 03 Z06 it was just plug in, no check engine light and it passed.
Just like the way it was supposed to be when they passed the law like 6 years ago!
http://www.bar.ca.gov/pdf/CAL-VIS%20...ng_2_13_13.pdf
Duck soup is a reference to how easy it was.
You know how to make duck soup?
Boiling water and a dead duck.
http://dictionary.reference.com/browse/duck+soup
