Stiff clutch pedal
#44
So you're saying put the same thing back in that I just got done running around in circles trying to figure out? I'm sure you can appreciate the irony. It sounds like I just got a bad pressure plate, but now I'm very skittish. The 4th time I have to drop the trans, I'd like it to be something that has a higher chance of having a soft pedal, so that leaves OEM or LS9. One reason I don't want to get the LS9 is I will never, ever, use it to its full potential and it's also difficult to justify the cost when I want to do 5-lug wheel conversion and freshen up the motor.
#46
Also did you get a ls7 replacement slave or the shim for the stock cts-v slave?
#49
As shown in the page out of the shop manual posted by someone on here, 52 ft-lbs, in the correct sequence: https://ls1tech.com/forums/cadillac-...l#post17875457
This is my 3rd time dropping the transmission. It's not intimidating, it's annoying. It kills the whole weekend. I took Friday off because I knew I would be doing a lot of troubleshooting...otherwise I'd almost be out of time. 4th time is no biggie IF I know it's going to work.
#50
Got the car back together and fired it up. I forgot how f'ing soft the stock pedal was. Basically feels like there's nothing there, but it went into 1st, 2nd, and reverse very easily. It engages at the proper height off the floor, and no weird noises. Great success!
#52
As far as you know, what kind of clutch life am I looking at with the mismatched setup? Unknown mileage on the flywheel, 3k miles on the resurface. 80k miles on the factory clutch...I figure its torque capacity will be lower, but my stock disc has tons of meat left on it. I figure it can at least get me from A to B for a while, yeah? I'll most likely get a new C6 clutch/flywheel combo, but wanted time to think on it.
#53
I have no idea what to look for. The pressure plate looks perfectly fine. The disc isn't shredded, there are no extreme heat spots on the plate or on the flywheel.
If you have shop access, remove the pressure plate and operate it with a hand press or lever to see if you can feel any binding.
I wouldn't even hazard a guess on clutch life on a "frankenstein" setup.
Not an insult, but too many variables.
#54
I would have the pressure plate assembly looked at.
And that's not an insult. It definitely is a hodge podge setup right now, but at least it works like it should! Just crossing my fingers it doesn't give me any problems for the next month or so. I'm thinking I should at least partially treat this as a new clutch break-in.
#55
Interesting read. Hope you out the culprit. It's like reading a mystery novel but not finding out who done it.
I know you don't want to spend the coin on an LS9 twin-disk, but they are nice. Smooth as heck.
#57
I reread this thread a few times and you never indicated what or where you got the pressure plate.
I was going to ask you for a list of all components and if they were new or used.
Furthermore, you indicated you got a flywheel that is "OE".
The OEM flywheel is a dual mass POS so if you got a single, your clutch was replaced.
#58
Yeah I don't have any direct shop hookups to do that. Plus, that has a very low priority right now. If it looked like it were a problem with the car instead of the clutch, I would try to inspect it sooner, but it would appear that if I put a brand new clutch in directly from GM instead of a reseller like Gripforce, then all should be well.
#60
Alright, I've dealt with this too long and it's time to make a thread. Long story:
Stock clutch and everything was working fine, but I like to upgrade things before they break, so I went ahead and got the philistine Tilton kit and installed it some time in November. I noticed an increase in pedal pressure, but it's hard to remember since I swapped in a C6 clutch, flywheel, and slave from Gripforce a few weeks later. With the new clutch, it started becoming more apparent that the pedal was a lot stiffer than it should be.
Originally Posted by Fweasel
I'm gong to drink a beer in your honor. Maybe two, because you dropped the trans so many times.
