About to maggie my LS2.. heads or no heads?
I'm about to install a maggie on my ls2 v with 48k.. I had Martin @ tick spec me a custom cam at 223/239 118+4. I was planning on a set of trick flow 225s or similar, but is it worth the 2k price tag? I was planning on 1:1 rear pulleys and the 10% overdrive crank pulley as well. Any help would be awesome guys. Thanks.
I would do them last if you do them. A cam and headers are a much better hp/$. Our stock heads are pretty good. I would say 20 hp more is about all you would see with heads on a Maggie and maybe 1 psi lower boost pressure.
My cam was worth 35hp on the top end and 50 in the middle for 1/2 the cost. Not sure what headers are worth.
