Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Radiator died. upgrade?
Old 11-05-2015, 10:12 PM
go4lucas's Avatar
Default Radiator died. upgrade?
Hi guys, my radiator died and i'm looking at my options. As it turns out the 3.6 radiator is the same and i found them for like 80 bucks but I was wondering if anyone had any luck with the ebay 'universal' aluminum dual pass radiator fitting in our cars.
Old 11-05-2015, 10:30 PM
itsslow98's Avatar
I know guys have used Alradco but you do need to make some modifications. Personally Id just buy one off rockauto.
Old 11-06-2015, 11:56 AM
BudRacing's Avatar
If a stock radiator lasted 10+ years, I would certainly buy another OEM stock radiator to replace it.
Old 11-06-2015, 04:17 PM
bmylez's Avatar
The key word there is **OEM**. People who buy the cheap non-stock replacements have gone through 4 or 5 of them. I didn't modify anything really for the Alradco...I shaved off a tiny bit of the water pump and core support with a hand file for a little more clearance, but it wasn't necessary at all.
Old 11-06-2015, 08:15 PM
Lbar's Avatar
Spectra Premium (NAPA part) on Rock Auto for $143. Great piece.
Old 11-06-2015, 11:32 PM
4doortypels's Avatar
Alradco is a nice piece... I doubt I'd spend that coin again on it. Sure does make everything harder to work on. My engine temps remained the same so I'd say a stock radiator is pretty efficient. Especially for a 3.6l. Forced induction or a track driven car may be another story
Old 11-13-2015, 10:09 PM
azn2dmax's Avatar
Get the GM OEM radiator for the 3.6 (regular CTS) they are exactly the same.
Old 11-14-2015, 11:27 AM
demang's Avatar
My Alradco need zero modifications to fit. It was a direct bolt in.
Old 11-17-2015, 02:04 AM
Vcaddy71's Avatar
I went with the Ron Davis and it is a really nice piece, but comes with a really big price tag as well. I was able to make it fit with the intercooler and AC condenser. It took a lot of patience to install though, and had to relocate the power steering cooler to make everything fit.
Old 11-17-2015, 08:23 AM
runsfromdacops's Avatar
summit 189$ alum rad here.had to weld to fit but @ under half the cost of the RD or allradco i think it was worth it
Old 11-18-2015, 11:23 AM
BudRacing's Avatar
New info to me. I'll have to check it out when the time comes. Thanks.
Is it the same part number too?
Old 11-18-2015, 11:46 AM
azn2dmax's Avatar
Part number for the V6 radiator is AC Delco 21512 / GM 89022478
Go to this link as it has detailed pics:
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/697065-oem-radiator-2004-ctsv.html#/enter
Old 11-18-2015, 12:06 PM
BudRacing's Avatar
Awesome info, thanks again! Stupid V tax!
Old 11-30-2015, 09:42 AM
BudRacing's Avatar
Just so happened to have my radiator let go this weekend. Came out to a puddle on the garage floor this morning. Ordered the 21512 and some new hoses from Rockauto. $204 shipped. Stock radiator lasted to 147.5k and 11 years. I think I'll take my chances with another AC delco.
Old 12-10-2015, 04:29 PM
BudRacing's Avatar
Just thought I'd note that the 21512 radiator fit perfectly.
Also, I replaced the water pump with a C5 Z06 part type which was $100 less than the V part. The fan shroud was already clearanced slightly for the deeper bell shaped pulley and went in without a problem.
Old 12-12-2015, 04:08 PM
go4lucas's Avatar
I bought a cheap one for 80 bucks and it died in a week..I guess thats what I get. So now I'm going to rig a universal mustang aluminum radiator on there because i'm tired of the plastic crap and I dont want to spend almost 500 bucks on the alradco one. Will post pics when its done.
Old 12-12-2015, 06:14 PM
Gus_Mahn's Avatar
Mine is starting to leak around the top crimp. Where did yours start to leak? Is it worth doing the thermostat and water pump while the radiator is out as PM?
Old 12-12-2015, 07:30 PM
go4lucas's Avatar
Mine leaked from the top as well. I did my water pump a while back because it leaked but I wouldn't bother swapping it unless it's leaking or unless you're bored. You could do the water pump and thermostat without removing the radiator if you wanted to do it later on
Old 12-14-2015, 10:05 AM
BudRacing's Avatar
Why not go with the GM part I used? It was $143+ shipping on rockauto.
Old 12-14-2015, 07:16 PM
Gus_Mahn's Avatar
I ordered the V6 radiator AC Delco 21512 / GM 89022478 for $128+tax from my local dealer. I have a friend in the parts department who hooks me up. Thanks for the info.
Quick Reply: Radiator died. upgrade?
