Lorenzen's Progress Thread
#141
I say this because I have already had someone use your torque specs, and were worried if they over torqued the bolts. If we are going to put information out onto the internet, it may as well be correct, right?
#142
Sometimes your mechanical knowledge shows with little stuff like this. The bolt head diameters are what you said, but the diameter of the bolts are not. Just in case someone breaks a bolt, the actual diameters (and what you will look for online, or ask a store clerk) are 16mm front, 14mm rear.
#143
The Scammer Hammer
I hate to bump this as I thought it had blown over, but apparently that's not the case.
Fuzzy, you posted *** backwards torque specs and got called out on it.
Nobody is "posturing." And yes, I do think you need lectured on torque specs. You're wrong.
This banter needs to stop.
#144
#145
The Scammer Hammer
No I get it. I'm aware of the history. Just because I'm now "named" as a mod of this section doesn't mean it's my first or ten thousandth time in here. I think the entire WORLD is aware of the history.
All I'm asking is in the future, let's all get along. The days of bickering and banter need to end.
