8.8 fluid capacity?
8.8 fluid capacity?
Could any of you 8.8 guys verify the fluid capacity for me? Is it 2 qts + the little bottle of friction modifier? I just drained the oil after 3,000 miles of installing mine... 1.25 qts came out which I know isn't right (I had a leak for a while which is why I'm draining). I'm gonna let the RTV dry overnight and then re-fill tomorrow.
Thanks!
Thanks!
Thanks!
Thanks!
Point is, you may not use quite all the gear oil but you want to use all of the FM.
Why not? I see why that would be frustrating. But also potentially dangerous. It's all about keeping the gears oiled and a lot of that is splash/sling. Aftermarket covers, unless they have the same exact contours as the stock cover, can and likely do change the overall capacity of the diff. I am fairly sure this is why the accepted method is fill til full and put the plug in. Basically to get a certain level in there, not necessarily a certain volume. You could in theory have a BIG cover that adds 1qt capacity and then with 2qt your level would be very low and possibly hurt your diff/gears/bearings.
Here's a link to the cover. The instructions with the cover say to fill to OEM specs. But if you look at the picture the fill hole is above the axle centerline which is why I can't use it as the level. Thanks guys, I'm going with 2 qts!
Thanks!
Thanks!
I also use a lube locker 8.8 reusable silicone beaded gasket for the diff cover. No leaks so far and way easier to manage than the RTV mess from Ford.
