OEM Lug nut part #
OEM Lug nut part #
Noticed I'm somehow missing 2 lug nuts. I've been trying to figure out what exactly I need but can't figure out from this diagram which I actually need: http://www.gmpartsdirect.com/auto-pa...at/wheels-scat
Which part # is the correct one? I'm just looking for a normal lug not a locking lug.
I've had some conflicting info at the parts counter when getting new lug nuts. The ones on my car are similar to, if not the same as the ones on my 99 Blazer. So now when I need another, that's the vehicle I reference. They're the open-ended with outer threads for caps. 19mm heads.
I wasn't able to dig up the actual OEM part number but for future reference these nuts fit perfectly: http://a.co/eKEiBvB
I found them locally at O'Reillys. Part # 611-263
They're just 12mm-1.5 lug nuts with the standard 60deg taper set, nothing special. Any auto parts place should have lug nuts that will work (as tnw found at O'Reillys).
From what I can see, the OEM part numbers were 09596069 (for the type with the separate screw-on cap) and 09596863, both of which are no longer available (NLA). I'm sure there are other GM part numbers that will work, so it seems strange to me that the online parts databases don't show those old part numbers superceded by some other newer part number.
