Can some please help me i have an issue with my 05 cadillac
Hi i have an 05 cadillac cts and i dont know whats the problem it has when i try to start it it doea not click or start but the dash lights stay on, i can jump startbit from the starter relay so i know nothings wront with the starter and the battery and alternator are fine because i got them tested so besides all these things i dont know what can be the problem can some one help me
Hi! I have an '05 Cadillac CTS and I don't know what's the problem it has when I try to start it. It does not click or start but the dash lights stay on. I can jump start it from the starter relay so I know nothing's wrong with the starter. The battery and alternator are fine because I got them tested. So, besides all those things, I don't know what can be the problem. Can someone help me?
^^^ There's some help.
How old is the battery? Can you jump start the car the normal way (in other words, not by bypassing the starter relay, but by hooking up jumper cables from a running car to the battery)?
My opinion is if you can jump start the solenoid on the starter like you said... But not any other way.. then it sounds like an ignition thing. Doesn't sound like a security issue with the chip in the key or it wouldn't fire off when you manually jumped it either.... Maybe you have a blown ignition fuse or something. Check all those. Try to jump it with just cables on another vehicle like stated above. Do steps to diagnose and find out what does and doesn't work. My guess is a blown fuse, or bad ignition switch not making the proper connection.
