What tranny will work on 2005 ctsv
For the record, any of these trannies will work: https://duckduckgo.com/?q=tranny&t=ffnt&iax=1&ia=images
I know because Mercier said so...
If you had an LS2 wire harness and ECU from a 2006-07 V and ls2 engine from a gto, AND all the accessories from an LS2 Ctsv... You'd have an easier time. If you run the Ctsv ECU (for an LS6) it's probably not gonna work straight away with the ls1.. without tuner changing things.
There would be a tune needed but it would probably run without. The LS1 and LS6 aren't worlds apart..Cam and 15% better head flow. What about MAF and O2 sensors? OP, do you have those from the V or from the GTO? At this point I think we are far past the transmission questions and on to what it would take for GTO engine in the V. So this is the info with which you will confirm that the swap is feasible in general--enough so that you would invest in the transmission. I'm not desperate to sell and would rather you make sure you are confident on the overall path before you commit to the T56.
The overall sentiment is that it should work, but don't expect it to drop right in and plug into the existing harness perfectly. The parts to make it work are out there and available, both new and used. It may need a CTS-V specific oil pan, a few different shapes of sensors, a wire or two extended, etc. One solution at a time. If you keep your eye out for a set of 243 heads, you'd basically have an LS6 again. You could also have the existing heads ported with similar or better results.
So here is #1 definite difference GTO vs. CTS-V: Oil Pan. GTO looks to be front sump and V is rear. This I think is required. Good news is the GTO oil pan is likely desirable for certain other swaps.
Link to all popular oil pans and dimensions/pics:
https://ls1tech.com/forums/conversio...-oil-pans.html
Exhaust manifolds GTO vs. V anyone? I do have a set of stock V1 manis sitting around also.
Here we have the explanation of the accy spacing, Corvette/V closest, F-body/GTO mid, Late Camaro/Truck farthest out. Truck will almost certainly NOT fit. I think we need someone with a assembled V to measure the tightest spot of accy to radiator/fan clearance(probably ABS and such too) to see if GTO drive would work.
https://www.lsxconcepts.com/product-...drive-systems/
PS-- Since I am a classifieds addict, here is some info on the GTO bellhousing:
https://ls1tech.com/forums/parts-cla...l#post19564214
