Cadillac CTS-V 2009-2015 (Gen 2) Welcome to a whole other level of overkill
let me make the first post to this sectionbest bang for buck mod
Old 06-15-2016, 10:44 AM
Karch's Avatar
Originally Posted by blacktransam
No real budget. I just want the car to still be a luxury car that my wife can drive to work in the rain.
There are so many options available.
You can even change the cam, keeping it mild, and pick up a ton of power.
I need to post a write up on my website, but you can pick up close to 200 rwhp and still keep it mild enough for the Mrs, though that number would require flex fuel.
On pump gas, you can pick up about 150 rwhp and keep it mild.
Really, it's mostly about budget.
Cheapest and best return for the money is a 2.55" upper pulley, Airaid intake, and a good tune.
Old 06-15-2016, 12:02 PM
blacktransam's Avatar
Yeah, already ordered the intake, and bout to do the whole pulley set up from Metco. Probably going to press the button on the American Racing headers and mid pipes as well. Keep the stock axle back
Old 06-15-2016, 12:08 PM
Karch's Avatar
I strongly recommend you using a Lingenfelter pulkey set up rather than Metco.
You can pm me if you wonder why.
Also, adding headers will probably lead you to needing injectors.
I would have suggested a writte I would have suggested a Grip-tec 2.45" pulley but that would have also required injectors.
Old 06-15-2016, 03:04 PM
LS1Tech Sponsor
Tony @ Mamo Motorsports's Avatar
Heads/cam/blower/heat exchanger upgrades are next.....if you truly want the "quiet power" sticking with the OEM exhaust will work the best but naturally that costs you some power but there are still alot of ponies to be gained if your willing to swap out significant internal parts and have the car tuned etc.
I can help you with an entire combination if your interested. My V drives like stock and has about 700/700 at the wheels (does have headers and an aftermarket X pipe etc.). I can knock down 20 MPG on the freeway if I keep it 80 MPH or less.
PM me if you like or lets just get on the phone if you would like to discuss your options in more detail.
How did you like the TB upgrade btw....have you ran it yet!?
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old 06-15-2016, 06:08 PM
Yes please pm me why, I have used Metco before (not on a V)and had good results.
Also Tony, when is a good time to call?
Old 06-16-2016, 08:31 AM
Does anyone make a bolt in kit to delete the cats and crushed section of piping under the car?
Old 06-16-2016, 08:47 AM
The Scammer Hammer
dr_whigham's Avatar
B&B makes test pipes, but for the price you may as well go with longtubes.
Old 06-18-2016, 09:42 PM
LS1Tech Sponsor
Anytime....I work practically 24-7....crazy hours....just leave a message if I cant pick up. Might be in the shop or on another line etc.
My mobile is best to contact me
(661)714-1317
Cheers,
Tony
__________________
Old 06-24-2016, 05:59 AM
Nicelysedate's Avatar
(661)714-1317
Cheers,
Tony
Tony,
I just bought a 2011 V. I will be contacting you for lots of upgrades soon!
Do you have cores for ported throttle bodies? If not I will purchase a new throttle body and send it for porting.
Thanks!
Old 06-24-2016, 10:24 PM
LS1Tech Sponsor
Originally Posted by Nicelysedate
Tony,
Thanks!
I have everything you need in house.....new LS7 units.....new LSA units.....exchange (used) LSA units.
We can discuss in more detail when you're ready to pull the trigger etc.
Cheers,
Tony
__________________
Quick Reply: let me make the first post to this sectionbest bang for buck mod
