09-15 Poly Front Control Arm Bushings
Front control arm bushings are finally available.
These will come with a 10.9 flange head bolt that has a grease zerk so you can grease the bushings periodically like you would a ball joint. We recommend using silicone grease(if you plan on getting a grease gun for yourself. Grease the bushings usually every oil change.)
Also these come with a Nordlock washer for both the head of the bolt and the nut side. These will help stop the sporadic alignment change.
We will begin shipping first come, first serve. We already have a few orders in. We should be able to ship out most orders, but like most things, depending on how late you order, you may be low on the list and it may take a couple days to get your order out.
If you have any questions, I should be able you answer them.
Here is the link to the website:https://creative-steel.com/shop/09-1...-arm-bushings/
-Jordan
-Jordan
Haha, we are working on it!
Control arm bushings? Uppers or lowers? We should have everything done for the rear the first quarter of next year.
So the bushing that is on the knuckle? Not the cradle/subframe side?
That is actually more a bearing than a bushing, it shouldn't have gone bad.
If you're referring to the bushing on the arm itself that bolts to the cradle, than yes, we will have them out hopefully real soon.
