Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Bob Johnson's V revisited!
Old 02-20-2009, 05:19 AM
EPP
EPP's Avatar
Thumbs up Bob Johnson's V revisited!
http://www.exoticperformanceplus.com...Car.php?car=29
You can check out Bob's V at the above link. Bob
Old 02-20-2009, 05:38 AM
venom ws7's Avatar
Very nice I love that V.
are those HRE??
Old 02-20-2009, 08:41 AM
jerrad's Avatar
Did you do anything about the airbag? A guage coming at your face at 200mph wouldn't be fun.
I'm in love with the car though. Looks great.
Old 02-20-2009, 08:42 AM
EPP
EPP's Avatar
Thumbs up
are those HRE??
Yes, they are HRE's. Brent and Drew just went out and did some filming of the V doing burn-outs. We'll post it up when we get a chance. Bob
Old 02-20-2009, 09:45 AM
deedubb's Avatar
Seriously guys, quit rubbin this stuff in my face
Looks like a wet dream on 4 wheels. Great Job!!
Old 02-20-2009, 10:20 AM
DoctorNick's Avatar
Can't wait for the videos.
Whats the deal with the gauges? How do the side curtain airbags work with the gauges overthem?
Old 02-20-2009, 10:31 AM
92nsx's Avatar
Very nice V, but it would go faster and have more HP if it were blk on blk
Still i bet it is one hell of a ride once the tires hook up.
Old 02-20-2009, 11:16 AM
Capown's Avatar
FUQ man every time I see these bad A$$ V's I can't sell mine. Some day I want mine to be as bad *** as chefs or skydrivers not sure what bob posts as but this one as well. So far I have some of the looks.
Nice job
Old 02-20-2009, 12:01 PM
LT4POWR's Avatar
I'm not a big centrifugal supercharger fan, but I'm really jealous of the rearend swap, and I like those subframe connectors.
Old 02-20-2009, 02:26 PM
CTSV_510's Avatar
Nice job
That is skydiver's car.
Old 02-20-2009, 03:16 PM
NEED MO POWA!'s Avatar
That is an awsome ride! where did u get that gauge pod?
Old 02-20-2009, 04:03 PM
onebadcad's Avatar
Sweet, 14.4psi is damn nice on Luxury Cadillac Sedan.
Old 02-21-2009, 12:52 AM
raven154's Avatar
I dont know were or how the obtained theirs but here is a single I've been working on. Originally it was for my car but his one is more than likely sold. I'm going to try and buy a few more pillars to make a twin and triple pod. I personally want a triple as long as I can keep it clean. If not, the single or maybe a twin would be fine with me as well.
http://www.cadillacforums.com/forums...ess-not-3.html
Old 02-21-2009, 05:54 AM
EPP
EPP's Avatar
This V made 815 on a different chassis dyno, I think we'd see 900 rwhp if we upped the boost. The F-1A blower on my 408 cid Camaro is making 19 psi, so we have quite a bit of room to grow with this V. We're also using a bone stock LS2 intake manifold on this V, I'll bet that the new FAST 92mm intake manifold would make quite a difference. Bob
Old 02-21-2009, 06:00 AM
EPP
EPP's Avatar
http://www.gmhightechperformance.com...tsv/index.html Bob
Old 02-21-2009, 11:52 PM
raven154's Avatar
The airbag is not in the a pillar. They are behind the headliner just over the door.
Old 02-23-2009, 05:09 AM
EPP
EPP's Avatar
Since we're using a bone stock LS2 intake manifold, which has proven to be nothing to write home about, I wonder how much more horsepower we would see with the above intake manifold? Bob
Old 02-23-2009, 06:03 AM
skydiver's Avatar
Bob, Is there room for that intake ?
Thanks, Bob
Old 02-23-2009, 08:28 AM
raven154's Avatar
An LS6 intake flows better than the LS2 even though its only 78mm. Since it seems you spared no expense on this vehicle, I would have a sheetmetal intake fabed that still fits under the hood. With as much boost as your running, I dont know I would even go the fast 92 route but it would without a doubt improve your numbers over the LS2. I do believe there are guys with more boost running the fast intakes though.
Old 02-23-2009, 08:32 AM
raven154's Avatar
One like this
Precision MetalCraft's line of sheetmetal intake manifolds can take your LS1, LS2, LS7, or L92 to the next level. A raised 3-inch profile and one-piece tapered runners with integral velocity stacks (for smooth airflow transition) offer significant improvement over the factory piece. Billet mounting flanges have factory-style O-ring grooves for a great seal, and a bottom-mounted fitting plate includes one 1/4-inch NPT and three 1/8-inch NPT female fittings for additional lines. Billet fuel rails are included and tapped to accept -8 fuel lines and either factory or aftermarket injectors. Each intake is available with either a 75mm or 90mm throttle-body opening, and retails for $2,250.
138 S. Vinewood St
Dept. GMHTP
Escondido, CA 92025
760/741-1539
www.precision-metalcraft.com
Quick Reply: Bob Johnson's V revisited!
