Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
BMR pinion brace, Creative steel diff bushing installed.
Old 01-09-2010, 12:00 PM
maxspeed96ct's Avatar
Default BMR pinion brace, Creative steel diff bushing installed.
Very happy with how the car drives right now.
Smooth as butter between shifts, no clunk, no thump... Nothing at all.
No extra noises with the pinion brace either.
I had the UUC diff bushing, but after I blew the Diff last month I decided the bushing was to solid. I think the diff needs some slight moment when lots of torque is transferred.
-First the diff bushing , I got the creative steel bushing with gray Polly.
After some examination I decided it was still on the solid side so I took a 3/8 drill and made 6 3/8 holes around it .This will allow for just little more play but not as much as the soft stock bushing.
And wow was this thing a Mother****er to install. I think creative needs to shave a little more off the O.D.
-The the BMR pinion brace. The bushing on this is also sold as a rack, So i took a drill bit and made about 6-7 holes around it just like I did with the bushing. And also I didn’t use the washer they give for the main 22mm bolt. It was to big and just presses the bolt right up the brace. Which can cause noise transfer. I found one that had a smaller O.D.
BMR had the right idea when they made the brace, But the polly they use is way to stiff. You still want the ability for slight movement or all that Torque will go right to the aluminum case.
Also If I do brake another diff, the BMR brace should hold the driveshaft from breaking when it whips around like my last one did.
(Sorry I don’t have any pics bros, my garage just looks like a bomb went off after doing the diff swap and I was on a mission to get the car done today)
Old 01-09-2010, 12:41 PM
jerrad's Avatar
Glad everything went on. When I installed the bmr stuff I had access to a lift so it was cake. I'd kill my self if I did it on my back.
Old 02-02-2011, 10:09 PM
DrSpeed's Avatar
is the Creative Steel bushing website up yet?
Old 02-02-2011, 10:57 PM
Fuzzy_Wuzzy's Avatar
bringing back an old thread...
but yes it is up now.
http://creative-steel.com/home.php
Old 02-02-2011, 11:40 PM
DrSpeed's Avatar
Thanks!
Can't blame me for using the [SEARCH] feature, right?
Old 02-03-2011, 10:29 AM
JNR_Design's Avatar
to the OP if he sees this:
How's everything holding up a year later?
I can't wait to get my bushings and mounts done and more than likely am going the CS route. I'm curious how the bushing comes out, in that they rent a special tool, but is it really a special tool, or can I do it the normal route (with press fit bushing)? I'm thinking it's gonna be a PITA doing it under the car though and wondering if this special tool helps in our situation and thus worth the $$?
Old 02-04-2011, 10:59 PM
4doortypels's Avatar
is that brace worth the money or would you get that tc girdle
Old 02-05-2011, 11:48 AM
DrSpeed's Avatar
That's what I was thinking.
Old 02-06-2011, 11:19 AM
adanieljohnson1's Avatar
OP sold his car...
Quick Reply: BMR pinion brace, Creative steel diff bushing installed.
