Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Hmm, clutch seems to have lost pressure
Old 04-01-2010, 05:58 PM
DoctorNick's Avatar
Default Hmm, clutch seems to have lost pressure
Its always before a trip, right?
So the peddle feel has gone away completely. It travels about 2/3rd of the way to fully clutched in without any resistance. Then the last 3rd, I can feel it bite and engage.
hydraulics?
I also have been having an issue getting into 1st at least once a trip now.
Guess its off to the dealer. I hope they don't give me **** for having a ls7 clutch in there.
Old 04-01-2010, 11:54 PM
itsslow98's Avatar
Trouble going into first is very common with all T56s so I wouldnt worry about that just release the clutch and push it back in and itll go right in.
I would hope since the LS7 is a GM direct part that they wouldnt hassle you.
Old 04-02-2010, 08:18 AM
punishmentcycle's Avatar
make sure the longer clutch line isnt sitting on the exhaust or kinked.. do u have the ls7 slave or using spacer? mine has been perfect
Old 04-02-2010, 08:59 AM
DoctorNick's Avatar
I think I have a LS7 slave. I had a dealership tech do the swap when I was last home (out of town for work).
Old 04-02-2010, 09:59 AM
the clutch line on thatslave is 10'' longer than stock.. i had to bend and zip tie it up away from the manifold...could be that the line is on the exhaust and boiling the fluid or just burning a hole in the line... best bet would be to bleed it and check the line routing..took me awhile to get the line where i was happy enough to leave it
Quick Reply: Hmm, clutch seems to have lost pressure
