Ummm Confused???
Ummm Confused???
OK, so RANDOMLY the audio in my V just stopped working?? The Nav Unit has full power and everything works, just no volume at all!!!! Being an electronic guru I searched and looked and tried to determine the cause, but no luck! I was really avoiding having to open up the dash and get behind there but it's looking like my last option. Anyone else ever run into or heard of this happening? Also, do you know where the BOSE amp is located, I think it could be a blown fuse... Any help is appreciated!!!!! Thanks!
Start with the bose amp. That sounds like the most likely cause. The amp is located on the drivers side quarter panel in the trunk. I believe the fuse for it is under the rear seat. Look at this it has schematics for the amp so you can trace power and ground....
http://www.cadillacfaq.com/faq/answe...eep/index.html
Did you check signal in and signal out on the amp. That may tell you a little more. If you aren't getting a signal in then I would pull out the nav unit. It's not that hard. There are instructions on cadillacfaq that I referenced above. It takes like 5 mins to get it out. Just be careful prying on the bezel. Good Luck. I hope for your wallets sake its not the nav unit.
Being that you're a electronic guru with 'no meter', try looking at the pins on the plug to the amp . . . . . . ? ? no meter?? . . .maybe an investment in a DVM would be your . . .
"next mod" and yes, I know, everybody likes a nice ***, but nobody likes a wise-*** . . . but sometimes I cannot help myself.
Okay so I'm not trying to be a smartass but if you expect to have any chance at diagnosing this you're gonna have to go get a meter. You can get a cheap digital one for almost nothing at radio shack. When you said power and ground on the amp are OK did you just mean you physically looked at them and they looked OK?
