Maggie plus Nitrous
Maggie plus Nitrous
I have a intercooled maggie 2.6 pulley...6lbs of boost...can i add a 75 or 100 shot of nitrous safely? and do i need to have it tuned again if i do add nitrous?
im no expert
but a good nitrous controller is a must and making sure your fuel system is capable. I also do not know the limits of the shortblock and pistons
I would talk to nitrous outlet
YES you will need to retune. Also when nitrous goes through a positive displacement blower like yours its going to pick up more then its pilled for. Id start with a 75, you'll get over 100 out of it
+ 1 ^^^^^^^ plus make sure your clutch and all are in good shape for the added power.
it should last but with that much power your talking easily of 600 crank hp, how long can a forced induction stock shortblock hold that. Ill be pushing that envelope as well soon so just dont be suprised if it doesnt hold together.
Iv heard 550 rwhp is max on stock short block....i just wanna spray 75 shot on it ....its already plenty fast...it has the ls7 clutch and flywheel and level 4 tranny...i will only spray in 3-4 gears also
That clutch will not hold. It is rated for 500 at the crank in a 3000 lb car, you want it to hold 550 at the wheels on a 4000lb car. It held a 150 shot on mine at the drag strip fine but unless your maggie only makes 50 whp then you are going to be out of luck.
i can get a used nitrous kit on here for about 300-400 bucks...im gonna do all the bmr suspension first and lowering springs i think...might hold off on nitrous and see if the car still hooks...btw the nitto nt05 are badass tires for these cars...hook really well for the power i have!
ya like i said easy hp for the money. But you want it to be safe when making maggie power, you gotta be carefull.
does a kit for 3-400 include everything needed for a wetshot? im not fimiliar with kit pricing but id want a bottle heater and a setup that turns on and off with the throttle.
Id just maximize your setup the way it is with a blower friendly cam that will just help with your power all around.
LS7 clutch will hold depending on driving style. My car did 500+rw on motor and 650+rw on the first stage, it held fine for awhile on the first kit but as soon as i started grabbing the big kit the clutch would go up in smoke
Yup exactly, 3-400 isnt going to buy you a good kit , cant go wrong with a good cam kit ontop of a maggie. Costs alittle more but you can have feel alot better about pushing the car hard.
