High pitched whine sound coming from the tranny???
Hey guys,
I posted about this awhile back and I didn't get much luck as to an answer to my issue. Randomly, my car will sometimes whine from what sounds like the tranny or maybe the clutch. It's a high pitched whine sound and usually is triggered when I shift to 5th or 6th gear. While driving, I pulled the shift boot up to see if that's where it was coming from and it got louder. The sound seems to go with the speed of the car. If I speed up, it gets a little louder and if I slow down, it quiets down again. Usually just a complete stop and go again will stop it. It doesn't happen all of the time but it happens more often than I'd like it to.
Anyone have any ideas? My reverse synchro is a little screwed up. It was like that when I got it but everything else shifts like butter. Any average person would prob grind reverse in my car but after driving it for awhile and using it, I seem to have mastered using reverse now without letting it grind. Lol
Just trying to get an idea of what could be causing it. It's not a throwout bearing sound because the clutch pedal doesn't change the noise. I'm not ruling out the fact that it could still be clutch related though.
Thanks for the info man! That's a good idea! I called a buddy of mine that works as a transmission mechanic at the chevy dealer over here to ask him. He said without looking at it, there is no way to tell for sure. He said he would rebuild it for me on the side at his house for $500 if I pull it out and $600 if I just drop the car off. Pretty cheap IMO and he uses better than stock parts. I know I could use a reverse synchro but the rest of the gears are perfect. I doubt it really needs a rebuild. It's just weird that I have this random whine at times.
I was really just hoping someone here had experienced the same thing and could tell me what is most likely causing it if they ever figured it out.
Let me know if you find out what the problem is.. Mine does the exact same thing.. Its not all the time but just enough to bug the **** out of me! It seems like its ok until I get into the thottle then it starts happening and wont stop for a bit. I cant tell if its the tranny or if its coming from the rear end. Keep me posted if you find it. Thanks
Silverstripe... I thought I was the only one! Glad to hear someone else is experiencing the same thing. My temporary fix is to turn the radio up a little louder but I'd really like to eliminate the problem. I'll let you know if I figure it out.
Gus... I'm hoping you are right about that. Sounds like a fairly inexpensive fix other than maybe the labor.
My cousin is a tech at a near by Chevrolet dealer and he strapped the chassis ears to the rear end thinking my 3rd gen diff was whining and it ended up being the bearing. Sucks replacing the whole shaft just to fix the bearing.....
I was told these diffs do tend to whine. I don't think mine whines at all. It's doesn't seem to come from the rear of the car. It comes from around the shift boot area it seems.
Mine did the exact same thing. See my previous post.
My mechanic also stated that he believed it to be that damn carrier bearing. We may try to pull the driveshaft and see if that sucker can somehow be rebuilt.
LAW
LAW
I'd think any decent driveshaft shop could fix/balance it for well less than $900. FWIW my 97 F-150 was about $220 for three u-joints, center bearing, and balance five years ago at a local driveshaft shop.
I'm 99% positive. If it were the rear, it wouldn't start doing it when I shift into 5th or 6th. It would be constant right? This sound starts sometimes in 3rd or 4th gear but it usually starts when im shifting to 5th or 6th for some reason like I said. And it doesnt happen everytime either.
When we lowered the car, I had my rear seats out and the noise wasn't any louder. It seems to come from the tranny area... Not from the rear.
does it start whining earlier if you do some hard launches? try some out mine whines depending on how hard i drive it and if i hit a big bump in the road will set it off also...
