Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Safe places to jack the V from...?
Old 08-11-2010, 01:48 AM
wes8398's Avatar
Question Safe places to jack the V from...?
If you want to leave your actual jack points open for placing stands, where are good alternative places to actually lift the car from? I've recently gone from under the spring perch in both the front and rear, and I've also used a 2x4 and gone along that frame rail (?). Any other suggestions?
Old 08-11-2010, 07:18 AM
TriGuy's Avatar
I would go just a small distance away from the actual specified point. put the jack stand right next to the jack itself and there you go. what I did with mine and worked fine. I just went slow when lifting it up so I could watch the side panels and make sure there was no load on them.
Old 08-11-2010, 12:26 PM
JJSimon904's Avatar
I use the frame rails
Old 08-11-2010, 02:57 PM
SoJersey05V's Avatar
rails
Old 08-11-2010, 03:42 PM
4doorvetteLV's Avatar
Use the frame rails underneath the triangle specifiers.
Old 08-11-2010, 04:30 PM
OldRoadDawg's Avatar
http://www.cadillacfaq.com/faq/answers/jackpuck.html
Put your jackstands nearby
Old 08-11-2010, 05:28 PM
wes8398's Avatar
I had forgotten, but I remember mention of those pucks before. Safe to say that even without the pucks, where the pucks go would be safe as a jack position using a block of wood or something.
Quick Reply: Safe places to jack the V from...?
