Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Express window issues?
Old 09-09-2010, 04:51 PM
Gus_Mahn's Avatar
Default Express window issues?
My drivers front express window feature no longer works going up. Everything else works fine. The window works fine other than no express going up. Is this an issue that my GMPP will cover? Dealer said maybe. Bring it in.
Old 09-09-2010, 05:18 PM
calimanv's Avatar
try this:
Programming the Power Windows
If the battery on the vehicle has been recharged,
disconnected, or is not working, you will need to
reprogram each front power window for the express-up
feature to work. Before reprogramming, replace or
recharge the vehicle’s battery.
To program each front window, follow these steps:
1. With the ignition in ACC/ACCESSORY, ON/RUN,
or when Retained Accessory Power (RAP) is
active, close all doors.
2. Press and hold the power window switch until the
window is fully open.
3. Pull the power window switch up until the window is
fully closed.
4. Continue holding the switch up for approximately
two seconds after the window is completely closed.
The window is now reprogrammed.
Old 09-09-2010, 05:53 PM
Gus_Mahn's Avatar
Battery did die while doing the brakes. The reprogram worked. Thank you!
