Harmonic balancer for Ls2??
Is the harmonic balancer for the Corvette ls2 the same as the CTS-V ls2?
and or does anybody have the OEM part number for cross referance?
Need to order one ASAP, and summit can't verify.
Mine desided to seperate, and the outter shell startet moving forward, took out both my belts and chewed up my wire to the MAF sensor while it was at it. Good times.
Thank you.
I was looking at ATI's web site and ther Balancer says it fits the V and is the same as the Vette and the ls6.
Part # 917266 OEM diameter.
What is the difference between an ATI damper as opposed to say Summits damper?
Other than cost.
I think when I had my whipple installed breifly it did in my stock damper, then when I took th SC off and did some wot drives it finally let go.
Other than cost.
Yes tht is a beautifull piece, above my budget right now.
I was going to go with the ATI from summit, but then there would be a delay in shipping, and I need it ASAP. So I went with the Summit racing brand. It's still sfi certified and should be 100X better than the stock one.
