mod bug is biting
mod bug is biting
Well it's time for some modding, problem is im on a 2k budget, i found a clutch kit for $500 http://easttexasmusclecars.com/produ...ain/slayer.htm Does anyone have any experience or should i just go with the monster stage 2?
I want some cut outs so I need to find a good place to get them best price,
I also need all mounts/bushings replaced so im thinking CS everything.
Or should i just say f@ck it and get nitrous kit and fuel system?
I personally would donthe clutch and stuff, bc if you just do nitrous you are gonna need a new clutch shortly after anyway. I have cs mounts and love then. I have a monster stage 3 on order right now should be here soon. Get a light flywheel i have heard they make a worldnof diffrence on these cars.
Stay away from the Hendrix clutch. The first one that tried it had to send it back and ended up getting screwed. There is a reason Hendrix is not on this forum(or the Cadillac Forums) anymore. I think someone ended up getting it to fit.
Ya you can buy basic kits for cheap but they don't come with everything you need. In the endnyou will be around 1k. And you can get cheap clutches that go with stock flywheel and stuff for cheap ya. But if you plan in doing or have mods you have to pay for a clutch that handles power. IMO I wouldn't buy a cheap clutch get one that you'll get your money out of. Ya know?
No worries bud, sad thing about it is the actual nitrous base kit is cheaper then the rest of the setup. Can you buy it and spray right then yea, but if you want safe and dependable you gotta get the extra stuff. Once you have it all setup and tuned nitrous is no more dangerous then boost.
yeah im thinkking with going with the ls7 kit from luke @ lindsay, its a lil over 600 with the light flywheel option. I think that way i can also get the mounts,bushings, cut outs and finally install the intake and get it all retuned. after that i'll start saving for a good nitrous setup
Just ordered my ls7 clutch from luke, creative steel motor mounts, trans mount, and shifter bushing. I can't wait to get these things installed along with the volant intake and short shifter, plus im going catless, so hopefully ill see a few gains on the dyno.
