Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Goodridge Stainless Steel Brake Line Installation
Old 03-23-2014, 02:34 PM
  #41
bmylez's Avatar
I thought I was almost done with car projects for the year, but with the multiple people who have said their stock brake lines have failed, I don't want to take the chance. Plus, my car lived most of its life in the Great Lakes area and I am moving to Ohio, so even more reason to do it sooner than later.
For the people wondering about which vendors carry these, it looks like Lingenfelter does: http://www.lingenfelter.com/mm5/merc...4#.Uy9Hes6W8g8
If they would be willing to price match with Amazon, I'd support them instead.
Old 03-23-2014, 03:56 PM
  #42
FuzzyLog1c's Avatar
I would buy the UUC lines through RacingBrake instead of these. The part number is BL920. I believe Modern Automotive Performance has the best price out there.
Old 03-23-2014, 04:05 PM
  #43
bmylez's Avatar
Not showing up on MAP's site, but I'll email them. I'm assuming the UUC kit doesn't have all the fitting issues that people have been experiencing with Goodridge.
Old 03-23-2014, 04:09 PM
  #44
FuzzyLog1c's Avatar
Correct, both times.
Old 03-24-2014, 04:03 PM
  #45
Closed ex-Sponsor Account
maperformance's Avatar
I can get them, Goodridge Part number 12219. At the time of this writing we have 4 in stock. Retail on them is 186.59 but I do have Forum pricing I can hook you up on. PM me if you have yet to hear back from us!
Old 03-25-2014, 01:40 PM
  #46
Cadzilla's Avatar
Originally Posted by FuzzyLog1c
That's excellent information. I already have both of the plastic versions, but ordered the aluminum ones immediately. Thanks!
I'm anxious to hear of your brake line swap solves your soft pedal issue.
Old 03-25-2014, 01:48 PM
  #47
FuzzyLog1c's Avatar
I'm sorry about the delay. I installed everything, bled the brakes, and then realized that I forgot to bleed the master. So I bled the master and have to re-bleed the brakes. Unfortunately, travel for work has been interfering with this process.
I should know for certain within a month at the outside. Since I have to remove the brake lines to install the GeForce 9", I'm not going to waste fluid bleeding the calipers at the moment. The soonest I can do the GeForce 9" is a week from Thursday.
Old 04-10-2014, 11:07 AM
  #48
Cadzilla's Avatar
So you have the new lines on, but still a soft pedal.. interesting.
I assume you re bled the master just to cover all the bases with the new lines?
My best friend just got a lift for his shop so I'll be able to do a much more thorough inspection on mine very soon..
Old 04-10-2014, 06:48 PM
  #49
FuzzyLog1c's Avatar
I rebled the brakes, and the pedal is much improved. Once I have the GM dealership run the Tech 2, I'm confident that the issue will finally be put to bed.
Old 04-11-2014, 12:06 AM
  #50
MarkOne's Avatar
I think this is the next mod I do to my ride. I want to flush my whole system with new brake fluid, so I might as well put new lines in while I'm at it.
When I changed out the brakes (lines, calipers, rotors, etc.) on my e46 m3, I kept the brake pedal pressed down with a broom stick wedged between the brake pedal and driver seat so only the fluid in the lines would be the only thing to leak while keeping the master cylinder full of fluid and keep as much air out the system as possible. Then bled the system with something similar to a motiv brake bleeder. I never had any problems and always had a solid pedal feel.
Old 04-11-2014, 06:50 AM
  #51
bmylez's Avatar
I think I am going to do this when I do brake lines. Thanks.
Old 04-11-2014, 06:21 PM
  #52
FuzzyLog1c's Avatar
That's not going to do you any good, because fluid will still drain out of the ABS system.
Old 01-14-2016, 06:12 PM
  #53
jmilz28's Avatar
This is an excellent mod, notable improvement over rubber lines, all else being equal. Having done back to back brake jobs/setups on my LS1/LS3 Camaro and old 1995 Suburban, the lines make a difference. Sure, some of it comes from the flush and bleed, but a big chunk also comes from the lines. Will be doing this mod on my 2005 V on its next brake job.
Old 01-14-2016, 10:55 PM
  #54
54inches's Avatar
***** where you been? We are trying to get a show together of V1 Htown dudes....
Old 01-15-2016, 05:24 AM
  #55
NIKDSC5's Avatar
I had better get an invite to that!
Old 01-15-2016, 11:18 AM
  #56
jmilz28's Avatar
Well, set it up!
Old 01-15-2016, 10:56 PM
  #57
54inches's Avatar
I have to get this damn restaurant open before I can play......
Old 10-06-2017, 03:30 PM
  #58
cadispeedster's Avatar
Anyone know the size of the crush washers? If I use the OEM ACDelco 21012386, will it work or do they have their own size?
Quick Reply: Goodridge Stainless Steel Brake Line Installation
