Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
OBX install
Old 08-11-2011, 07:41 PM
wcryan's Avatar
Default OBX install
Headers are installed. But I have a couple leaks. One is where the resonators connect to the stock exhaust. Were just gonna weld those. My installer said he's gonna run them through heat cycles and then re-tighten to try and get rid of the leaks
Did this work for anyone. Or did anyone have a similar problem
And if so what did u do to fix it? We all know header leaks sound like **** so all help would be appreciated
Old 08-11-2011, 08:14 PM
DMM
DMM's Avatar
I have both cat. converters and the straight connectors on two different exhaust systems (stock and Magnaflow) and they both required welding. Funny thing is that all the Magnaflow joints are connected with the same clamps and none of them have ever leaked.
Go ahead and get it out of the way, get them welded now.
Old 08-11-2011, 08:16 PM
jenks40's Avatar
Speaking from a leaking header on a bike... yes, I have ran a few times, loosened everything holding the entire system, wiggled, tightened the leaking area FIRST, and had success. However, I don't believe heat cycles had anything to do with my success. It was late, I was lazy, and I didn't feel like tearing it apart so I did it after a few days and a few rides.
Old 08-11-2011, 09:18 PM
liqidvenom's Avatar
where do you have leaks aside from that connection?
also how does it connect to the stock exhaust?
Old 08-11-2011, 09:42 PM
wcryan's Avatar
The resonators slip over the stock exhaust that you have to cut a little. The welding should fix that leak but I'm wondering if there is another way to fix the ones by where the headers mount to the engine without having to put new gaskets in
Old 08-11-2011, 10:20 PM
DMM
DMM's Avatar
The header gaskets are not too bad, the drivers side is real easy. You want to remove the battery and the plastic base and HVAC filter housing cover on the passenger side...takes a little time but makes everything sooo much more accessible.
Once the plugs are out, take out all the bolts except for the first and last. Trim the header gasket with snips and let it fall down and hang onto the bolts holding the header on the head. The stock manifold gaskets work just fine and are not too terribly difficult, about two or three hours to replace them.
A 7/16" or 12mm ratchet wrench will be your friend.
Old 08-12-2011, 10:17 AM
SoCA04V's Avatar
Might look into the ARP header studs if you're going to go through the work of taking it back apart. I hear it makes everything much easier, and less likely to leak.
Old 08-12-2011, 10:38 AM
wcryan's Avatar
Any recommendations on a better gasket?
Old 08-12-2011, 11:13 AM
SoCA04V's Avatar
I have read the OEM LS1 gaskets are the way to go. Did you use the ones included in the OBX kit?
Old 08-12-2011, 11:20 AM
wcryan's Avatar
Yeah. I didn't hear anyone having problems with them so I said **** it
Old 08-12-2011, 12:18 PM
LS2duc's Avatar
My installer didn't like the looks of the OBX, bought a new set of GM LS replacements. Resonators are welded up to the stock exhaust. No problems so far at 3 mos 3K miles.
Old 08-12-2011, 12:22 PM
wcryan's Avatar
Ok. Sounds good. Looks like I'm just looking at a gasket leak.no leak from resonators. I'll grab some OEM gaskets
Old 08-12-2011, 10:26 PM
LS2duc's Avatar
I wanna say fairly cheap, too. Maybe $40 for the pair?
Old 08-16-2011, 10:55 PM
liqidvenom's Avatar
do you know how long it took a pro to install headers?
Old 08-17-2011, 12:00 AM
wcryan's Avatar
it took my installer a little bit because of issues we ran into. Not exacly sure how long it took
Old 08-17-2011, 08:57 AM
LS2duc's Avatar
About three hours with lift...
Old 08-17-2011, 10:13 PM
dr.duct_mossburg's Avatar
Do they throw a CEL? I was looking at a set with what looks to be no cats?
http://www.eracingzone.com/ProductDe...de=OBXHeader29
Old 08-17-2011, 10:25 PM
LS2duc's Avatar
Exact same set I have. No cats, just look like 'em. No codes, tuner vanished those. I believe he shut the rear O2 sensors off.
Quick Reply: OBX install
