Replacing Maggie inlet - whats the torque for these bolts?
Does anyone here know the torque specs for the bolts for the maggie inlet? I'm going from a 78 mm TB to a 90 mm and am looking to torque these bolts correctly. I know the bolts for the TB itself are 89 in-lbs but I can't find info on the inlet bolts.
ctsv154?
ctsv154?
You dont want them so tight you distort the case or the snout since they are aluminum. I also used longer bolts because the stock ones would have only been threaded in by about 3-4 threads it seems. My "just snugged" solution has been holding fine for the past two years. So has my anaerobic sealant (locktight) snout gasket.
