Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Alternator/Battery/Starter Problem - Looking to check ground wires - help please
Old 10-07-2011, 04:25 PM
kws87's Avatar
Default Alternator/Battery/Starter Problem - Looking to check ground wires - help please
Hey everyone,
I think my alternator is out on my 04 CTS-V. When I turn the ignition it clicks once and then hums. Before I spend a small fortune fixing this I have read that faulty/loose ground wires could cause the same problem - and I would greatly appreciate it someone could tell me where those are and what to look for. Thanks much
Old 10-07-2011, 04:44 PM
BudRacing's Avatar
There is one on the passenger side behind the tail light and there is one on the base of the hood strut. I'd check the rear ground first, but it could just be your battery depending on it's age.
Old 10-07-2011, 05:24 PM
1BADCTS's Avatar
I believe there is also a ground on the back of the passenger cylinder head. Did the battery and alternator test ok at autozone? That's always my first check... after making sure my battery terminal's are tight on the battery of course.
Old 10-08-2011, 12:34 PM
kws87's Avatar
My battery is just under 2 years old. I would love to take it to AutoZone to check - however the car decided it wouldn't start at all yesterday afternoon. Any way I could check to see if its the battery at this point? Thanks for the help
Old 10-08-2011, 12:52 PM
CancerJCC's Avatar
All ground locations with pics can be found here: http://www.cadillacforums.com/forums...s-here-11.html
Although I think you just need a new battery.
Old 10-08-2011, 01:01 PM
kws87's Avatar
If it jumps does that mean its the battery?
Old 10-08-2011, 01:16 PM
wcryan's Avatar
my battery went to **** in about 2 years. I was pissed
Old 10-08-2011, 03:56 PM
kws87's Avatar
I tried jumping the car but got nothing. The car is showing a battery voltage of 11-12 if that means anything. Still just making a "click" when I turn the ignition. Thanks for the help
Old 10-08-2011, 04:15 PM
Skidmarcx's Avatar
First thing to check is the health of the battery... Fully charged it should read 12.66 volts... Could be several problems... Bad/Cheap battery, faulty alternator, faulty starter, bad connection... List goes on. Cheap batteries will stress the alternator and starter causing premature failure... Not saying you have a cheap battery, but it is something to be aware of
Old 10-08-2011, 05:35 PM
kws87's Avatar
I will try to get a ride up to AutoZone and take the battery with. In case it helps anyone diagnose the problem -
My first notice of it not starting right away was only this past Wednesday, 2 tries to start and it just "clicked", started right up on the 3rd try. Happened again Thursday in much the same way, called the dealership to make an appointment. I drove the car and it happened again - but started right up after 4-5 tries, but otherwise I was driving around like normal all day. Then, yesterday (Friday) afternoon - nothing, just the "click"....followed by sadness
I appreciate the help, LS1tech always comes through.
Old 10-08-2011, 06:05 PM
CancerJCC's Avatar
Just get a new battery and go from there. Which I suspect will be the end of your troubles.
Old 10-10-2011, 01:03 PM
kws87's Avatar
In case anyone ever has the same problem. Battery tested fine, I hard started the car and drove it to the shop. It started fine a couple times right after driving it and the shop wasn't able to replicate the problem today (like I haven't heard that before). Also, alternator tested just fine.
Possibly just had the starter locked up? No idea, just hoping it doesn't happen again. Thanks again
Old 10-10-2011, 01:17 PM
Skidmarcx's Avatar
I'd really look into your battery/ground connections as well as the positive cable going to the alternator and starter
Old 10-10-2011, 02:56 PM
joehernandez86's Avatar
When mine did what your describing it was the battery. Also might want to check your connection from the alternator plug to see if its in good shape i had to replace mine when it started showing low voltage and battery light. I think there is a Service bulletin on the alternator plug.
Old 10-10-2011, 03:07 PM
AlamoTA's Avatar
It really sounds like a connection problem. Possibly corrosion under the insulation. You have just enough connection to allow the click, but sometimes corrosion won't allow enough amperage to turn the starter. I'd check both ground and power wires for corrosion under the insulation at the terminals,starter, and grounds. Good Luck! I'd lay money on one of your main wires going bad.
Quick Reply: Alternator/Battery/Starter Problem - Looking to check ground wires - help please
