Time for some kicks
Time for some kicks
Hey guys im in the process of looking for some new wheels. Just wanted to see if yall would post what yall got and the specs. Thinking of 20s but idk how they would look. May just stick to 18s.
After looking at pics i agree. One problem now. The wheels i want dont come in 19s. If i put 20s how low can i drop the car to bring it back down? Or wat tire can i run to keep same height as the factories?
With the same width a 245/35/20 is the closest tire you'll find in width and diameter. It's only bigger by a 10th of an inch in diameter.
You can play around with this: http://www.miata.net/garage/tirecalc.html
Eastern Regional Coordinator
19 by 8.5/10 Linea Corse 855s.. lowered on H&R springs. dayum near perfect fitment(could use a spacer up front and without trailing arms not a lot of room to spare on the rear)...
Mind the dirt.
I love em
Mind the dirt.
I love em
Also a Linea Corse product from wheeldude.
BE FOREWARNED:
you'll likely have all kinds of "fun" making these wheels fit, especially if you're lowered. Search my threads on issues I had and how they were resolved. Good luck!!
Not really. use a known rim/tire combo to work then lowered and do either at any time. To install springs you have to take the wheels off...
If you get one of the 10inch rear linea corse setups. Try and find some MAP trailing arms. Without them the clearance is minimal.
Thanks for replys. Im actually going with a custome fikse wheel. Anyone know how wide of a tire i can stick on the rear without no major modifying? Once i find out ill determine how wide i want the wheel.
