LT's Q
If i were doing mods all over i would pick up a set of OBX headers and wrap them just like my stainless works headers. i have prodded between a few of the overlaps at the collectors and after 1.5yr they still look rust free, solid, and black(painted them in DEI header paint). paint on the exposed primaries has burned off though
My "redoo" setup
ObX headers->cats->stock 2.5 exhaust-> stock resonator -> muffler delete & 4in tips...
i have heard your shouldn't wrap headers if they are coated in a ceramic.. one or the other... also dont be lazy insulate every component around the LTs with some sort of heat shielding.. common V header problems lazy dudes have... alternator wires arcing .. brake lines charred.. starters fried... wires melted.. rubbing steering linkage... ect...
My "redoo" setup
i heard from a shop owner when at a dyno day in jersey that wrapping ceramic coated headers over heats the coating and reduces its life span.. aka the coating will crack... peal..ect..
IMO you gotta do something.. the bay in the V is to cramped for you to install them naked.. plenty of documented cases of the FAIL that follows
yes wrap is a fire hazard if youre lazy... get a garbage bag slice it open, lay it over the motor, cut a hole for the filler neck.. ROCKET SCIENCE
Do not wrap your headers if your car will see rain or snow. It will destroy them. It doesn't matter if they are stainless or ceramic coated. My 1-7/8" OBX "stainless" long tubes were wrapped. It rusted them out. Wrapped ceramic coating will be even worse as it contains aluminum and will carrode even faster.
You figure a stainless header will last 10 years or more. If you wrap them, you could cut that down to 3 years before you get pin holes.
Header wrap is for Race Cars or for cars that do not see moisture.
Ehh...this is a bit bias. Under normal operation conditions, the headers would be so hot that it would evaporate. The fiberglass wraps, especially when sprayed, do a good job of repelling the moisture anway. If you arent getting them hot enough, this could be true. But I would rather have the headers wrapped and have the piece of mind that my car wont be burning through wires than have to replace the headers a few years early. Not to mention, that most people probably wont have the car long enough to ever have to worry about this.
I guess at this point I just need to know if what everyone is saying could be true (cracking and peeling etc) Not a fun thing to do but has anyone removed the wrap after a good amount of time to check for peeling? Also it rains A LOT here in Seattle so any worries there?
Missed your post got it....thanks
Would you like a cookie? I'm not disagreeing that moisture and heat will cause deterioration...I completely agree there. My statement is whether or not the moisture actually stays long enough to have much of an effect before it evaporates. Like I said...I would rather have them wrapped and not have my car burn to the ground and have to replace them a bit sooner than to have them bare.
