Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
brake wiring help????
Old 10-26-2011, 09:41 PM
JOHN STEPHENS's Avatar
Default brake wiring help????
ok im installing my window switch and trying to figure out what wire gets hot when i hit the brakes. There is the black which i assume is ground. But then there is white one and one is blue. do you know which is which?
Thanks
John
Old 10-27-2011, 03:48 PM
Stepside's Avatar
I never heard of the brakes connected to the window . . ??
But,
White wire is 'low reference'
Blue wire goes to window motor for power up.
Brown wire is power down.
Old 10-27-2011, 04:26 PM
BudRacing's Avatar
I believe his "window" switch is referring to a nitrous oxide install.
Old 10-28-2011, 02:13 AM
yah its a window switch for no2 install sorry. and i found out that the white one gets hot when you hit the braakes, gotta connect there bc the brakes reset my first gear lockout. thanks guys
