Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
banging between gears
Old 02-21-2012, 07:42 AM
porkchop-rob's Avatar
Default banging between gears
Hello fellas. I purchased my first cadillac a week and a half ago and Im loving it. I picked up a 2007 cts-v in black with 75k on the clock. This is by far the fastest car I have owned, and after driving a civic for a year and a half, this thing is a BLAST.
My only concern is a noise i hear under hard acceleration when i let off the gas or clutch to shift. Each time i hear a loud bang or boom sound. It is way worse in the lower gears.
Here is a short video of the sound taken by my phone.
Any help is greatly appreciated.
http://www.youtube.com/watch?v=outAI...e_gdata_player
Old 02-21-2012, 08:16 AM
98cobra's Avatar
Check the motor mounts
Old 02-21-2012, 08:20 AM
Hate to ask such an amateur question...but what is the.best way to check. Am i looking for engine movement under load or am I looking at the mounts themselves for visable issues?
Old 02-21-2012, 08:30 AM
lollygagger8's Avatar
Look for brownish residue from the gel that comes out of them after the break and leak. It almost looks like an oil leak. The fluid is actually green before it dries into a brownish hue.
Old 02-21-2012, 08:33 AM
azn2dmax's Avatar
its hard to see if the mounts are visibly bad. Not a lot of room to see. Do look for excessive engine movement though. I changed my MM with UMI MM and love them but some people dont like them.
One of the problems in the V is the "clunk".
One of the upgrades to do is a short shifter if you dont have one ASAP. Hint hint. Buy one form me. LOL Shameless plug
https://ls1tech.com/forums/cadillac-...fter-70-a.html
Old 02-21-2012, 08:47 AM
punishmentcycle's Avatar
Diff bushing.. Jack up the car and push up on the front of the diff.. It'll prolly move a whole inch up and down. Any of the aftermarket bushings will solve ur problem
Old 02-21-2012, 10:10 AM
rjoffe's Avatar
This is also known as the "parade clunk". There are a whole host of reasons. Some have been mentioned above, but here is my list (in no particular order):
Engine Mounts
Tranny Mount
Diff Mount
Driveshaft coupler
Driveshaft bearing
Two piece flywheel
Old 02-21-2012, 10:13 AM
kl2onik's Avatar
Mine did the same with only 50k on it when I bought it. The motor mounts are most likely the problem plus you rear dif almost bottoms out cause of the bushings and wheel hop. If they are shot as bad as mine were, one side of my engine would almost come up and hit the ls support bar over the engine bay under hard accel. The motor mounts may look fine till you take them out. I went with the stock mounts again knowing they will have to be changed down the road since I'm skeptical of a stiff ride/road noise with the umi's. If you do get those there is a guy selling them on cadi forums for like 150. I know what you are going through cause it scared the $hit out of me the first time I drove this car hard, after my m3 this car sounded like going on a bad hay ride.
Old 02-21-2012, 10:39 AM
what caddi forums?
do you know the guys screen name?
i will replace with poly mounts if needed.
Old 02-21-2012, 10:46 AM
kl2onik's Avatar
what caddi forums?
cadillacforums.com look in the classifieds. I hate that site but thats just me.
here is the link directly just cause I woke up on the right side of the bed today)
http://www.cadillacforums.com/cadill...nts-21-21.html
Old 02-21-2012, 10:56 AM
thank you.
Old 02-21-2012, 12:49 PM
EdmundGTP's Avatar
maybe it's just me but i couldn't discern a damn thing relevant to the OP from that video.
Old 02-21-2012, 04:47 PM
If you turn up the volume, just as i let off the accelerator, and clutch, there is a boom. It not only a noise, but i can feel it in the car. I will get the car off the gtound and check the motor mounts as well as the diff bush. asap.
Old 02-21-2012, 06:29 PM
serik21's Avatar
Check your diff
Bolts as well if it ain't your diff bushing but it's prolly the diff bushing.
Old 02-21-2012, 06:42 PM
meatyCTS-V's Avatar
$20 says it's your motor mounts.
while you're doing them, also do your transmission mount.
Creative steele sells the whole shebang for like, $350ish.
A worthwhile investment, if you as me, good sir. I have mine in, and love 'em.
-meaty
Old 02-21-2012, 10:26 PM
odthetruth's Avatar
I'd go UMI motor mounts, and CS trans mount and be done with it. I'm pretty sure its the mounts also.
Old 02-22-2012, 05:46 AM
Racer001's Avatar
Same symptoms I had due to bad motor mounts.
I did the UMI motor mounts and Creative Steel transmission mount. My car feels TOTALLY different now. No more clunks or bangs. I can now rip through the gears because my transmission will shift now, as before it would get hung up between gears!
Best thing I've done to the car.
Old 02-22-2012, 07:57 AM
Brackets's Avatar
My money's on the diff bushing.
Old 02-22-2012, 02:51 PM
sod
sod's Avatar
when I got my '05 with just under 50k on it, it did the same thing.
My buddy asked if there was a bowling ball rolling around in the trunk.
New motor mounts & diff mount (stock) & the clunk is gone. 2 years later & it's still gone.
Old 02-22-2012, 06:02 PM
TokyoJoe's Avatar
Ah ****, nice. I was wondering what that was. I have a similar issue with mine, if I slip the clutch nice and slow it wont do it, but if I engage the clutch quickly I hear it.
Quick Reply: banging between gears
