Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Install Price Maggie/Cam
Old 03-14-2012, 12:11 PM
JayBirdWs6's Avatar
Default Install Price Maggie/Cam
What should I pay roughly for the Install and Tune of a Maggie and Cam?
Old 03-14-2012, 01:07 PM
RRsV's Avatar
Call some shops in your area and compare prices.
Old 03-14-2012, 02:01 PM
JayBirdWs6's Avatar
I did call around and got some prices 1700.00 & 3200.00 ($3200.00 )
Old 03-14-2012, 02:51 PM
Onefast V's Avatar
I would say 2000 seems around right. About 1000 for Maggie. 500 for tune minimum and minimum 500 for cam but probably closer to 800. Id do the Maggie yourself. It's not hard.
Old 03-14-2012, 03:13 PM
cam3439's Avatar
+1 on ^^. I did the maggie myself and then towed it in for the tune...saved that 1g on the maggie install.
Old 03-14-2012, 03:45 PM
Onefast V's Avatar
You can actually drive the car after the install as long are you stay out of boost conditions. IF you are driving under 20 miles to a tuner it would save having it towed. if its farther i would consider a tow.
Old 03-14-2012, 04:10 PM
04Vguy's Avatar
^this
Old 03-14-2012, 05:29 PM
dr.duct_mossburg's Avatar
I know you don't have a garage or somewhere to do it, but yeah I dont think the install is much but the cam is what will get you. Like other's have said, Maggie installation is 10hrs IIRC ($1000), $500 for tune and $500 for cam.
kl2onik's Avatar
good luck finding someone who knows what they are doing to only charge 500 for a cam install. Its an easy 10hr labor
Old 03-14-2012, 06:31 PM
04Vguy's Avatar
cam and spring job will usually take the better part of the day. ive done a few in my v and many many more in other cars and if you dont have to do the springs and you know whatt you are doin it only takes a few hours or more. if youve never don it and you do have to do springs good luck. that at a shop is easy 10+ hours and a couple days by yourself
Old 03-14-2012, 06:43 PM
kl2onik's Avatar
yeah that was my point cause we both know you need springs for just most cam jobs let alone a maggie. A cam spring job wont run you less than a cool g.
Old 03-14-2012, 07:15 PM
CTSV_510's Avatar
Really? It doesn't seem like driving 20 miles with 60lb injectors on a tune for 28lb injectors would work very well. I'm no fuel and tuning expert but it seems to me that you would be dumping fuel pretty heavily and cause all sorts of problems. Even if you get a maggie kit with 42lb injectors, it doesn't sound like a good idea.
Old 03-14-2012, 07:17 PM
CTSV_510's Avatar
I agree with the standard rates that the others said...$1000 each. I would also recommend doing your own maggie install. It was my first real experience wrenching and it wasn't a big deal. A buddy and I did it in about 10 hours I believe. As long as you can follow basic instructions it's an easy way to save $1000.
Old 03-14-2012, 07:58 PM
wcryan's Avatar
Did my Maggie install in my garage. Then had my shop overlook what I did and installed the magnavolt. Saved me a shitload
Old 03-14-2012, 09:09 PM
Onefast V's Avatar
The maggies all come with 42lb Injectors. Haven't been 60 for a long time. I drove mine to and from the dealer with no issues prior to a tune.
Old 03-14-2012, 09:12 PM
CTSV_510's Avatar
Gotcha, I didn't know that would work. Mine came with 60's.
Old 03-14-2012, 09:27 PM
itsslow98's Avatar
I would imagine around 2500 for install and tune on both. Do you have headers already?
Old 03-15-2012, 06:07 AM
JayBirdWs6's Avatar
Yeah already have headers
I want to install the maggie myself but dont have all the required tools listed on the instructions and it would only be me doing the install. Don't both cam and maggie installs require you to remove the radiator and the crank bolt.
Old 03-15-2012, 08:16 AM
cam3439's Avatar
I opted for the LS2 snout with a 90mm TB on my LS6, so I couldn't drive it to a tuner. The tuner still happened to be about a 2 hour drive from me too.
Old 03-15-2012, 08:39 AM
branland's Avatar
After I installed my maggie, it would start and stall. I had to have it towed to the tuner.
Quick Reply: Install Price Maggie/Cam
