clutch choice - LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Cadillac CTS-V
Log In
Search
Cadillac CTS-V
The Caddy with an Attitude...
clutch choice
Thread Tools Search this Thread
Old 03-26-2012, 05:19 PM   #1
rbsurfer's Avatar
Trader Rating: 0
Default clutch choice
i was gonna do a monster clutch but i wanna try the ls7 cause its a way better price. On SDPC they offer ls7 flywheel or a 19.5 lb flywheel ?? Is it even worth dropping to a 19.5 lb flywheel for a daily driver/ drag track 3 times a month car?
please comment if you alreaady have a ls7 clutch swap or have good advice to point me in the right direction.. thanks
__________________
2005 CTS-V MODS: K&N INTAKE, CORSA CATBACK, NGK TRX5's........ 1.955 60'-- 8.28 1/8-- 87.27mph 12.760 1/4 --110.20mph. Solddd
06 ctsv black on black 530 wheel
Sold!!
2010 c6 6spd intake long tubes for now
rbsurfer is offline   Reply With Quote
Old 03-26-2012, 05:24 PM   #2
BudRacing's Avatar
Trader Rating: 3
I went with the 28 lb factory LS7 flywheel. It's great for daily driving and a HUGE improvement over stock, but does feel like it could be lighter. I've heard others comment that they didn't have any problems with their superlight flywheels, but i suspect those lightweight flywheels may have something to do with a short clutch-life.
__________________
2004 CTS-V - Black on Black - Rolling restoration lowered on STS-V wheels with CS goodies, OBX Longtubes and DMH Cutouts.
BudRacing is offline   Reply With Quote
Old 03-26-2012, 05:33 PM   #3
rbsurfer's Avatar
Trader Rating: 0
possibly the fact that you have to slip the clutch a lot to get off the line ... idk
__________________
Sold!!
Old 03-26-2012, 10:39 PM   #4
Super-Mod
itsslow98's Avatar
Trader Rating: 18
Send a message via AIM to itsslow98
I would definetly do the LS7 over the monster as far as clutch, and I would stay with the heavier flywheel. 28lbs is already cutting the factory crap in half. Most who drop to the 18lb flywheels have driveability issues until the have the tune touched up.
__________________
-2003 10th Anniversary Cobra, Wiseco Pistons, Manley H-Beams, ARP everything, 98 Cobra Intake Cams, Hellion T76 Turbo, TH400 with Trans brake, UCC 3800 stall, Dynotech Chromoly DS, Built Solid Rear, 35 Spline Axles, Spool, Full Suspension, AIS Dual Nozzle Meth Kit. SOLD, thank god
-2005 CTS-V, Kooks with HF Cats, Comp 232/236 .0600 114+2, HSW Wet kit...496hp/509tq. SOLD
-1993 Mustang Coupe-LS1/T56 Swap. 234/246 EPS cam, LS6 Intake, Kooks L/T, 4.10s, Mcleod Twin Disc. 417rwhp/389tq PARTED
itsslow98 is offline   Reply With Quote
Old 03-27-2012, 09:49 AM   #5
Trader Rating: 0
I have a personal vendetta against Monster so I'm leaning toward LS7. And yes for a daily driver you don't need to go ultra light on the flywheel. Makes a difference in stop and go traffic.
__________________
-- 2006 Red CTS-V -- 402 forged stroker -- TVS 2300 supercharger -- Meth -- Need I say more!
ichpen is offline   Reply With Quote
Old 03-27-2012, 10:59 AM   #6
Trader Rating: 0
I went with the 18 lbs flywheel, and at 1st the car stalled out more(I have a cam and it the car sometime hunts for idle) after about 700 miles The car stalls less on its own. Whenever it does hunt for idle it finds it quicker.
Stop and go traffic hasn't seemed to be a problem for me yet. The car does bog down a little easier if I do not give her some gas coming off the clutch.
__________________
2005 CTS-V Livernois Stage 2 Cam, Kooks headers, off-road connecter pipes, Corsa exhaust.
hnic91 is offline   Reply With Quote
Old 03-27-2012, 01:04 PM   #7
lollygagger8's Avatar
Trader Rating: 5
I have a 18lb Monster FW, no issues here......besides the Stage 3 chatter once in awhile, till I beat it back into submission with the skinny pedal and then it goes away.
__________________
Mamofied AFR 215 heads, Mamofied Fast 102 intake, 227/231cam, Nick Williams 102 TB, Yella Terra Rockers, Gforce 9" Rear End/Axles/Driveshaft, Level 1 Monster Twin Disc Clutch, LAPD remote, wrapped B&B headers, hi flow cats, B&B xpipe & catback, Volant CAI, Hotchkis Sways, BMR Trailing Arms/Bushings, Rev Shift Motor Mounts, PISINUOFF Shifter/UUC Bushings/Trans Mount, Brakemotive Drilled & Slotted Rotors, F14 Forgestar Wheels, CAGS Elim, DDM HID Fogs, STS Fogs, Clear Sidemarkers
lollygagger8 is offline   Reply With Quote
Tags
choices, clutch, ls1tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
