Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Cadillac CTS-V
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
Cadillac CTS-V
The Caddy with an Attitude...
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 05-05-2012, 11:40 AM   #1
Garage is empty, add now
NeverSatisfied02's Avatar
Trader Rating: 11
Default Idle clip of my exhaust setup...
http://www.youtube.com/watch?v=AjFHqPkxwWI&feature=plcp
First youtube upload. Lol Took the clip yesterday and figured id load it to show y'all what my exhaust currently sounds like.
Nothing fancy so don't get too excited. Ill get some better clips soon with whatever mufflers i decide to run on it.
__________________
-Silver 2005 Cadillac CTS-V
VRX5 cam, OBX 1-7/8 catless LT headers, X-Pipe, Corsa, Volant CAI, MSD wires, NGK BR7EF plugs, Creative Steel 8.8 (4.10) w/ 1000hp axles, Diamond stage 3 clutch w/ 15lb billet flywheel, Ground Control 500/550, FG2's, MM kit, Z06 endlinks, BMR strut tower bar, UMI solid motor mounts, Rev Shift tranny mount, Katech ST shifter, Brakemotive drilled/slotted rotors/pads, Zex wet kit w/ Nitrous outlet plate, etc. Tuned by G-Force... 550hp/553tq
NeverSatisfied02 is offline   Reply With Quote
Old 05-05-2012, 11:56 AM   #2
2005 Cadillac CTS
kl2onik's Avatar
Trader Rating: 3
i wouldnt bother with the corsas sounds good as it is. I have the corsas and cam and basically your package and its not worth it. Muff delete sounds just as good imo. Not sure what drone people are talking about since Ive never experienced it with the corsas but if its that bad maybe its worth it. Regardless with full boltons cant take this car past 4k or it sounds rediculous...Im kind of past the 16 year old fart canon phase and car is too loud imo
kl2onik is offline   Reply With Quote
Old 05-05-2012, 12:03 PM   #3
2001 Chevrolet Camaro
Adam L's Avatar
Trader Rating: 0
Car sounds good, look forward to hearing more.
Adam L is offline   Reply With Quote
Old 05-05-2012, 12:06 PM   #4
Trader Rating: 11
Oh it sounds great at idle and even revving it but driving it around town sucks. When it hits that 1800-2000rpm range under load, it has that unavoidable and obnoxious hollow/blatty sound. Sounds good before that and after that in the RPM's but that blatty sound at that point is bad enough for me to want mufflers. Lol When i'm rippin into it, it sounds 100% beasty! No complaints there! But... If i just drive it normal, i'm in that obnoxious RPM range on a regular basis and it annoys the **** outta me. Drone is pretty bad on the highway too.
If i was basing it on the idle and WOT sound alone, i wouldn't change a thing!
Here are some pics of the Corsa sport mufflers and tips i bought. I planned to change the tips regardless because the stockers are ugly as sin and too small but at this point, im thinking mufflers would be a good choice too.
I bought these and started browsing clips on youtube of cam'd cars with headers, no cats an corsa and the sound varies from clip to clip. Of course the no drone would be AMAZING! But... I also want that vicious sound i like outside the car as well and if i have to deal with some drone to get it, i will. Thats the only reason i'm hesitant to install them. Some clips with my setup and the corsa sounds deep, vicious and crisp but then some sound hollow and higher pitched. I know its hard to tell what it will actually sound like with clip online due to other factors like recording device quality, computer speaker quality, etc.
So... Im on the fence about installing these or running different mufflers. Deciding between Borla stingers, GHL bullets or even finding a used magnaflow catback (after hearing whistler151's old car on youtube with basically my same setup which sounds great) and adding electric cutouts in the future.
Idle clip of my exhaust setup...-corsa-1.jpg   Idle clip of my exhaust setup...-corsa-2.jpg   Idle clip of my exhaust setup...-corsa-3.jpg
__________________
Old 05-06-2012, 07:05 AM   #5
Trader Rating: 11
Did you get mufflers installed? I think you will still get a drone with the mufflers. You should add cutouts while your under there.
__________________
Livernois LS6 Stage 2 CNC ported Heads, 287 XER Comp Com ( 238 240 DURATION @ .050, .605int lift .609exh lift @ 112 LSA), Ported Fast 90mm Intake, 42lbs injectors, LS2 TB, Kooks w/o Cats, X-pipe, Corsa, QTP Low Profile Cutouts, CAI, KARS, B&M shifter. 438 RWHP/387 RWTQ Tuned by Livernois Motorsports
den_99_GTX is offline   Reply With Quote
Old 05-06-2012, 10:31 AM   #6
Trader Rating: 11
Not yet. Called the shop yesterday but it was already 1 and they were pretty busy. I'm going to get em installed tomorrow.
Im told it shouldnt drone with the corsa. Figured I'd get em welded in and see how I like it. Also found a used magnaflow catback for my car through a friend local so if I don't like the corsa, I'll just go with the magnaflow catback and add cutouts. Whistler151 had a cam and same exhaust setup as I do with the magnaflow catback and it sounds really good from the clips I've watched on YouTube. Either way... It's either corsa or magnaflow for me now.
__________________
Old 05-06-2012, 02:44 PM   #7
BudRacing's Avatar
Trader Rating: 1
Send a message via AIM to BudRacing
Wow, that thing is LOUD even idling in the driveway. I agree that must be a pain to drive around every day. It is begging for cutouts though. If it could sound like that with the flick of a switch--holy **** that would be amazing. I'd put some really quiet mufflers on it with cutouts.
__________________
04 CTS-V - Black. Lowered. Loud.
LS7 Clutch, CS mounts & diff bushing, pinion brace, AZN shifter mod, H&R's, K&N FIPK, ported & polished throttle body, Comp Trunion Upgrade, OBX catted LT's, res delete w. x-pipe, DMH cutouts, stock mufflers, MTI tuned, STS-V wheels, Black grilles, "Brembo Gold" calipers, Brakemotive pads n rotors, Red Z06 FRC's
BudRacing is offline   Reply With Quote
Old 05-06-2012, 03:05 PM   #8
Trader Rating: 11
Yeah... It's obnoxious. Lol I'll see if I can get a buddy to drive my car and do some cruising clips and some fly bys so y'all can see how ridiculous it is. Weird thing is its most obnoxious just cruising around. Idle and WOT it sounds good and is tolerable. Lol
Cut outs for sure though. Leaning towards selling this corsa sport setup I have and just going magnaflow with cutouts. I figure the magnaflow will be less radical and deeper toned so with cutouts, it'll be best of both worlds.
__________________
Old 05-06-2012, 03:10 PM   #9
BudRacing's Avatar
Trader Rating: 1
I have heard magnaflow drones...
__________________
Old 05-06-2012, 03:19 PM   #10
Trader Rating: 11
Hmm... I might have to PM whistler151 and ask him how bad it was cause his setup on his old car is exactly what I'd have if I went magnaflow. I can handle a little drone but too much is no bueno... Lol
__________________
Old 05-06-2012, 04:53 PM   #11
2006 Cadillac CTS-V
My Garage
LAYGO's Avatar
Trader Rating: 2
I think there's going to be a specific resonance frequency of any setup. Whether or not that is drone is a different question.
__________________
2006 CTS-V
- SW Hood/Spoiler - !Mufflers/XPipe - Brakemotive Drilled/Slotted - !CAGS - K&N CAI
- Azn2dmax shifter w/CS bushings - Ebay clear fogs/HID - Bel STi-R+ Detector (BAD ASS) - [CTS-V Parts I need]
1996 Impala SS
- Stage 1 Phoenix 4L60E - Catback - Stealth Brake Bolt - Tired LT1 - dents, scratches, droopy windows - Failed inspection
LAYGO is offline   Reply With Quote
Old 05-06-2012, 05:04 PM   #12
Trader Rating: 11
I know regardless what I run it will be heard from inside the car. That doesn't bother me. I actually like hearing it in the car to an extent. It's that deep annoying resonance/drone you get on the highway around 70 that I can't stand. On previous vehicles, I've just driven faster or slower to avoid it or turned the radio up. Lol But if I can avoid having to do that, it sure would be nice. Lol
__________________
Old 05-06-2012, 09:36 PM   #13
Moderator
2003 Ford Mustang Cobra
itsslow98's Avatar
Trader Rating: 18
Send a message via AIM to itsslow98
Sounds like ****. I think Cole's car sounds better then that.
__________________
-2003 10th Anniversary Cobra, Wiseco Pistons, Manley Rods, ARP everything, 98 Cobra Intake Cams, Hellion T76 Turbo, Built T56, Mcleod RXT Twin Disc, Built Solid Rear, 35 Spline Axles, Spool, Full Suspension, AIS Dual Nozzle Meth Kit. 701rwhp/763rwtq on 20psi..... BUILD IN PROGRESS
-2005 CTS-V, Kooks with HF Cats, Comp 232/236 .0600 114+2, HSW Wet kit...496hp/509tq. SOLD
-1993 Mustang Coupe-LS1/T56 Swap. 234/246 EPS cam, LS6 Intake, Kooks L/T, 4.10s, Mcleod Twin Disc. 417rwhp/389tq PARTED
itsslow98 is offline   Reply With Quote
Old 05-06-2012, 11:12 PM   #14
Trader Rating: 11
Lol! I would hope for his sake it sounds better since he won't be getting rid of it anytime soon and he'll be hearing it for years to come. If I can't get the sound I want, I'll just sell it and move on since my car will actually sell... Haha
__________________
Old 05-06-2012, 11:19 PM   #15
Moderator
itsslow98's Avatar
Trader Rating: 18
Quote:
Lol tahts funny, your cars sounds sick.....i do miss the hell out of the cammed sound haha!
BTW seeing and hearing your car, i can say with confidence its a solid 13 second car.
__________________
Old 05-06-2012, 11:35 PM   #16
Trader Rating: 11
Haha! Thanks man! This car has been a lot of fun so far. Much quicker and more fun to drive than my old one since it has the built rear in it. Just doesnt look as good... Yet! Lol I have a ported fast 92 and 90mm TB with nitrous outlet 92mm dual stage plate waiting to be installed. I'm about to order the fast fuel rails, 60# injectors, UD pulley and 160* stat and install everything at the same time so when I take it to g-force for the re-tune, it's all done in one trip. I may need a boost a pump though after all that. Not really sure at what point the stock fuel system isn't enough so I need to do some calling around to find out if I should find a boost a pump and install it too before the re-tune. Already have the drop springs and TF wheels waiting to go on. Just been lazy and havent installed them. I'll be doing that soon and ill make the other cosmetic changes I want to make to it soon as well.
And yup! Glad u could tell man! On drag radials, I managed to cut a 1.5 60 foot and barely got it in the 13's! haha Might have to come for that slobra soon... Lol
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
287xer, cars, clip, clips, dual, idle, ls1, powered, sand, sport, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
