8.8 swap and axles/driveshaft - LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Cadillac CTS-V
Log In
Search
Cadillac CTS-V
The Caddy with an Attitude...
Thread Tools Search this Thread
Old 02-24-2013, 10:31 PM   #1
RADEoN's Avatar
Trader Rating: 12
Send a message via AIM to RADEoN Send a message via Skype™ to RADEoN
Default 8.8 swap and axles/driveshaft
What are people doing for axles/cv and driveshaft? I'm looking to start accumulating parts but can't figure this **** out. I've heard there's a coupler to use my stock driveshaft for the time being also. I'd have no issue using stock axles and driveshaft for a few months.
RADEoN is offline   Reply With Quote
Old 02-24-2013, 10:39 PM   #2
NIKDSC5's Avatar
Trader Rating: 10
Send a message via AIM to NIKDSC5
Quote:
This is all in the diy 8.8 thread. Which ifrc they are at a stand still. There is no coupler yet to use the stock drive shaft, and i believe they may have figured a cheaper way with the cv's but nothing confirmed.
NIKDSC5 is online now   Reply With Quote
Old 02-24-2013, 11:35 PM   #3
54inches's Avatar
Trader Rating: 4
There is a coupler of sorts, but you will have to get with Gulf.
__________________
05 V - LS7 Clutch/Slave, JB Clutch MC, Tick Bleeder, RevShift MM/TM/Cradle Bushings, DV8S's Shifter, Sub Frame Connectors & 8.8, Pacesetters coated in/out, 3" full exhaust, magnaflow X, flowmasters, G-force tune; 389rwhp
54inches is offline   Reply With Quote
Old 02-25-2013, 07:03 AM   #4
Bowtie70SS's Avatar
Trader Rating: 10
What about this?
http://www.driveshaftshop.com/2004-2...nversion-plate
For $150 you can use your stock shaft
__________________
2004 CTS-V
2003 Silverado SS LQ9
1970 AMC Rebel Machine
My never ending 70 LS2 Chevelle build thread http://ls1tech.com/forums/conversion...lba-toast.html
Bowtie70SS is offline   Reply With Quote
Old 02-25-2013, 07:53 AM   #5
NIKDSC5's Avatar
Trader Rating: 10
Correct me if im wrong but to use the stock drive shaft it will have to be cut, shortened, and rewelded. Then, rebalanced which is not something alot of shops are capable of since it is so long.
Old 02-25-2013, 09:54 AM   #6
54inches's Avatar
Trader Rating: 4
Quote:
Originally Posted by Bowtie70SS View Post
What about this?
That's the one.
Quote:
WE are trying to confirm that.
AGAIN, let's post this over in the unified thread so we don't have tech spread out all over.
__________________
Old 02-25-2013, 10:50 AM   #7
NIKDSC5's Avatar
Trader Rating: 10
Quote:
__________________
2005 CTS-V -484RWHP/453RWTQ-12.1@117 So far.....
-Alum CS 8.8 3.73w/TruTrac, 1pc CF DS, upgraded CV's
-Mcleod RST w/15lbs steel FW, PMC master, TDP stage 2 trans, Hurst w/all linkage bandaids
-All CS Bushings, trans mount, UMI MM,
-406ci LS2 w/ A.I. 232cc 243 Heads, Fast 90/90, Brute speed blower cam, coated OBX 1 7/8," magnaflow CB
-Plenty more
Similar Threads
Thread Thread Starter Forum Replies Last Post
wtb gto driveshaft tyler318 Parts Wanted 1 03-16-2015 05:20 AM
Driveshaft help BlackCowl New LS1 Owners - Newbie Tech 1 02-05-2015 12:25 PM
Can you use stock driveshaft with MWC 9" rear end? 95LT1Z28 Gears & Axles 8 01-15-2011 11:48 AM
Tags
07, 88, axles, cadillac, chevelle, coupler, cts, ctsv, driveshaft, ls1tech, manual, shaft, stock, swap, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
