Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What trans fluid should I use?
Old 10-30-2013, 07:36 PM
69stangscj's Avatar
Default What trans fluid should I use?
I have 50k on my car and I've had it for about 3 months so I decided to change the trans fluid out with Dexron VI, I figured it was backwards compatible and didn't give it much thought. After the flush It seemed to shift better than what was in there, but then I seen some posts on here and decided to change it back after around 500 miles to Valvoline Dexron III in fear of messing something up. Now it doesn't shift as well and I'm not sure if it's because its colder out or the fluid sucks. The owners manual says Dexron-III as does the side of the trans. What's your guys thoughts?
Old 10-30-2013, 07:57 PM
TeamSorad's Avatar
https://ls1tech.com/forums/cadillac-...sh-anyone.html
Post 5 (fuzzy) it's 3 quarts Redline D4 ATF and 1 quart Redline MTL 70W80 GL-4
I have used it with no problem, tranns shifts great 110k
As far as the dex3 or dex6 I'm pretty sure GMC doesn't use 3 anymore so everything uses 6 which will work with no problem and is backwards compatible. I would use the above redline though
Old 10-30-2013, 08:09 PM
bmylez's Avatar
I've seen multiple people recommend Mobil 1 synthetic ATF. I just changed mine out for Mobil 1, looked to be original fluid at 66k. Basically any high quality ATF that meets GM requirements is fine, though. No real right answer.
Old 10-30-2013, 08:13 PM
69stangscj's Avatar
The gear oil is kind of concerning, this is from the Tremec site:
A hypoid gear oil by design does not allow mechanical surfaces to make contact with one another. A synchronizer relies on friction (much like your car's brakes) to do its job. Thus, gear oil in a synchronized transmission can be a bad combination, potentially causing a variety of shift quality issues. Furthermore, many gear oils contain sulfur additives that can damage friction materials.
Old 10-30-2013, 08:17 PM
FuzzyLog1c's Avatar
If you put Mobil 1 ATF in your transmission, it'll sound like a rock grinder and shift like one. Ask me how I know.
The most optimal mixture is 3 quarts Redline D4 ATF + 1 quart Redline MTL 70W80. You can go as high as 50/50 if your transmission is really old and/or battered, but you're going to experience some additional parasitic losses due to the thicker mixture.
Old 10-30-2013, 08:21 PM
69stangscj's Avatar
Yea, not sure what to think here. Did you see the post: "How to turn your transmission into a rock grinder in one easy step with Mobil 1"?
Old 10-30-2013, 08:23 PM
69stangscj's Avatar
Fuzzy, is this a home bru or how did you come up with this mix?
Old 10-30-2013, 08:33 PM
bmylez's Avatar
Hmm, I haven't noticed any adverse effects...I believe I followed the How-To on the other site. What's interesting to me is there are a bunch of ATF specs posted on there as well and Mobil 1/Redline are almost identical. Obviously more to the picture than just those specs, but I just find it interesting that they can have such different properties otherwise. I'll give this fluid a little more time, but I'll try your Redline concoction in the near future.
Old 10-30-2013, 08:38 PM
jmargo's Avatar
I run what the sticker on the side told me to. Shifts like I believe it should. I do live in Ca and the car sits in a garage so there is not the extreme temp shift as some states.
Old 10-30-2013, 08:55 PM
jfensty's Avatar
I run Mobil 1 and have for almost 60k. I now have over 155k on the car and still shifts great with no rock grinder noise. I have been wanting to change to amsoil torque drive that others have mentioned.
Old 10-30-2013, 09:25 PM
DMM
DMM's Avatar
I've tried almost everything from the Tremec recommended base Havoline DEX-III, to Mobil 1, and finally syncromesh. Royal Purple ATF will eat the friction lining from the syncro's.
In my opinion, Mobile 1 was the absolute worst by far. Syncromesh is pretty awful when cold (and the colder it is, the worse it is) but gets much better when hot, with a better overall feel than standard DEX-III. I now have a custom built T-56 Magnum and the builder supplied syncromesh with the trans...they won't warranty the unit without it.
Too many people have reported great success with the RedLine concoction for me to not try it myself, and will be next on the list after I get everything else in order. I have a friend who works at the largest BMW dealer in the area and he commented the same RedLine 75/25 or 50/50 mix has been used as an upgrade for a long time now, so I guess this is not a new thing.
Old 10-30-2013, 09:32 PM
Eastern Regional Coordinator
CTSVBiggie's Avatar
amsoil
bmylez's Avatar
How is Mobil 1 the worst if RP actually eats the friction lining on the synchros?
As a side note, I'm looking at Royal Purple's site and their Synchromax fluid states "Synchromax is recommended for manual transmissions that specify an automatic transmission fluid." I'm not saying anyone should try it, but it sounds like it could potentially be better than their ATF for our trans.
Old 10-31-2013, 12:16 PM
KamaSutra's Avatar
I've used Mobil 1 ATF , Royal Purple Max ATF Dexron III, and the Redline DF4 + MTL 70W80 GL-4 combo.
I'm currently running the Redline combo and I like it best out of the three.
Old 10-31-2013, 07:46 PM
meatyCTS-V's Avatar
I'm running the D4 ATF straight.
When I drained out the old fluid, it had the viscosity of water lol
Oils are just like anything else, you've get the same number of horror stories as you will success stories with one or another.
Old 10-31-2013, 08:40 PM
Fweasel's Avatar
amen. I'm running Dex VI like the 07 manual calls for, and despite the Dex III sticker on the side of the trans.
Old 10-31-2013, 09:44 PM
NIKDSC5's Avatar
Do what fuzzy said! I promise you, you will be amazed at the difference. Before his mix I ran mobil one for 2,000 miles, terrible. Then did royal purple syncro mesh for 3,000 or so miles with some improvement. Then put in fuzzy's mix.....NIGHT. AND. DAY.
Old 10-31-2013, 09:46 PM
MN_V's Avatar
Sometime in 2006 our T56 was 'certified for Dex VI'. Whatever that means... not sure if is backwards compatible. I'd assume it is for the 04/05's unless some material was changed.
Old 11-01-2013, 10:55 AM
shadyLS6's Avatar
I have used amsoil torque drive for over 30k and it was a noticeable improvement over the stock fill
Old 11-04-2013, 06:29 PM
JDB
JDB's Avatar
M1 syn ATF here.
It meets the spec: http://www.mobiloil.com/USA-English/...etic_ATF.aspx#
Quick Reply: What trans fluid should I use?
