05 V Bad window regulator?
Well I rolled the front passenger window down and when it got to the bottom I heard a loud bang and now the window seems like it is off track and doesn't move up and down smoothly. The motor seems to be fine so I am assuming it's a regulator. Sound right to you guys or is there something else that goes bad on these things? If it's a regulator can I replace just the regulator or is it a motor and regulator deal. Thanks in advance.
Thanks for the offer Junior-1 but I ordered it off Ebay last night. The window went back up after it broke, is that still consistent with a bad regulator? The driver side is acting weird too. It won't go all the way down in auto mode. It stops about an 2 inches from being flush with the door panel. Then if I press the window button again it goes all the way down and clunks. Is this a regulator problem as well?
