Would anyone be interested in some V1 weight information?
CTS-V Shifter Sales
Yeah....so tell me why again that is beneficial to the rest of us? This thread is just to find out stock weight, total and each corner. With that said, most of us will have different results as to what the after numbers (op sitting in his stock car) would be. Due to different mods of each, coilover choices, sway bars, weight reduction, frame stiffening etc. To see how the stock form of the car reacts to him sitting in it is worthless. As nothing can be done to correct it. There are no adjustments available.
I suppose you are correct if you just want the stock weights. My car was lowered with GC and QA1's. we went a bit off the OP's original topic.
Then, because the front right *is* heavier, you probably noticed it sagging on that corner and adjusted it up. That transferred the weight to the opposite corner. Obviously, it's not possible to have all four corners set the same height if weight distribution is unequal. So I think you did the right thing.
My mistake. I incorrectly assumed that you were on stock suspension as I was. That makes sense knowing you had coilovers.
Well finally got to throwing the car on the scales yesterday before doing my Alradco swap.
Bone stock 2005 CTS-V. Filled the tank to the click and drove .5 miles back to the shop. 32PSI all around on Nexen 3000 stock size tires.
Zero the scales:
Car by itself:
With 230# driver:
And another Alradco success:
It was late in the day so I didn't bother to bring out the scales again to check out the difference, but the Alradco thread has differences in their weights + the extra 1/2 gallon of coolant capacity.
Zero the scales:
Car by itself:
With 230# driver:
