Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Would anyone be interested in some V1 weight information?
Old 02-22-2014, 12:13 PM
05ctsV1's Avatar
Default Would anyone be interested in some V1 weight information?
Hey all. Quick introduction, been lurking on the V section of this board and the forced induction section (building a 4.8/80mm/t56 3rd gen on the side) for a year or two now. Just finally got around to registering as I picked up my V in August. 2005, bone stock. Bought it with 22k on the clock, DD'ing it, and it's up around 37k on it now.
Anyways, I was looking in the suspension tuning thread and didn't see where anyone was able to provide accurate data on exact weights. I have a Longacre scale at my disposal, and was wondering if you all want me to throw my bone stock car up on it to get you all a good baseline of total, corner, cross and front/rear weights? Just let me know how much fuel you want me to put in it and I can get you all some information in the next few days.
Edit: For easy information access...
Well finally got to throwing the car on the scales yesterday before doing my Alradco swap.
Bone stock 2005 CTS-V. Filled the tank to the click and drove .5 miles back to the shop. 32PSI all around on Nexen 3000 stock size tires.
Zero the scales:
Car by itself:
With 230# driver:
Old 02-22-2014, 12:26 PM
FuzzyLog1c's Avatar
Absolutely. Have you seen the Weight Reduction Checklist?
http://www.cadillacforums.com/forums...checklist.html
Old 02-22-2014, 12:42 PM
05ctsV1's Avatar
I did see that, maybe in a few years when she get tired I'll turn her into an autocross machine, but she is my dd at the moment so not enough of a ROI to start tearing into her yet.
How much fuel do you all run with? Seems like If a few pounds are worth some decent coin I can get you a close base. Maybe I'll just do a full, half, and an empty test.
Old 02-22-2014, 01:02 PM
FuzzyLog1c's Avatar
I always run with a full tank, but honestly, that's probably one of the easiest things to factor out if you really care.
Old 02-22-2014, 01:12 PM
RADEoN's Avatar
i don't even use fuel anymore that's how light my cts is
Old 02-22-2014, 01:30 PM
NIKDSC5's Avatar
I'd love to know what is weights full of all fluids.
Old 02-22-2014, 01:35 PM
UnsafeAtAnySpd's Avatar
This would be good. I've posted my corner weight numbers before as have others, but none of the numbers I've seen have been unmodded cars.
Old 02-22-2014, 02:39 PM
FuzzyLog1c's Avatar
Speaking of corner weights, I've been dying to get my car corner weighed. Unfortunately, it seems like most places charge about $500. Which is absolutely not going to happen.
Old 02-22-2014, 02:46 PM
NIKDSC5's Avatar
Wow that is a lot. Guess I'm going to have to fine someone with a set of scales I can borrow and do it my self.
Old 02-22-2014, 02:55 PM
AAIIIC's Avatar
Full tank. On track I only get about 9-10gal of fuel used before I start to get fuel starvation coming out of long, high g corners. Running any less than a full tank would mean I'd be filling up before/after every session.
Old 02-22-2014, 03:37 PM
serik21's Avatar
the best would be a car full of all fluids full tank and somebody in the driver seat let's face it our cars don't drive themselves on the track
Old 02-22-2014, 03:49 PM
Fuzzy_Wuzzy's Avatar
If you don't weigh it full of fuel at least go fill up afterwards so we know fairly close how much was in there
Old 02-22-2014, 04:29 PM
NIKDSC5's Avatar
Why would I want to know how much he weights? I know how much I weight, and I got 5$ says we don't weight the same.
Old 02-22-2014, 05:15 PM
CTS-V Shifter Sales
07CTS-V's Avatar
418 LS3 stroker, 1/2 tank of fuel.
Old 02-22-2014, 05:52 PM
FuzzyLog1c's Avatar
I assume that was without a driver? It's weird that you have that rear cross weight. The only asymmetricalities in the rear are the position of the XM Receiver and the Bose amplifier.
Old 02-22-2014, 07:10 PM
Quoting myself from another thread...
Originally Posted by UnsafeAtAnySpd
I figured some of you would like to know these numbers. These were taken with me in the car (about 168 lbs), my helmet in the passenger seat, about a half tank of gas, a few trunk interior pieces removed, some dynamat back there, Kooks headers, hi-flow cats, Corsa catback, sunroof, rear strut tower brace, BMR front brace, Optima redtop in stock location.
LF 1114 1084 RF
LR 924 896 RR
Front 2198
Rear 1820
Total 4018
And then later...
I went ahead and weighed it again yesterday. Changes are the clutch/flywheel, wheels/tires, rear seat removed, maybe a quarter tank of gas less (if that) and I've gained about 20 lbs...
3886 lbs!
I didn't record the corner weights on the last one, but it was the same set of scales.
Old 02-22-2014, 09:24 PM
OneSlowV's Avatar
Go to a truck stop and use the cat scales lol. 14 bucks is all it cost
Old 02-22-2014, 09:37 PM
serik21's Avatar
Yea non of us wieght the same but it would be nice to see how the wieghts per corner differ with a driver in the car. Bet you $5 not all his wieght will be on the driver side tire.
Old 02-22-2014, 09:45 PM
True. It will be interesting to see back to back results with and without drivers. I've been looking at the differences in 07CTS-V's and my numbers and trying to figure out why his left rear is noticeably higher even with me being in the car for my weigh in.
Old 02-22-2014, 10:07 PM
NIKDSC5's Avatar
Yeah....so tell me why again that is beneficial to the rest of us? This thread is just to find out stock weight, total and each corner. With that said, most of us will have different results as to what the after numbers (op sitting in his stock car) would be. Due to different mods of each, coilover choices, sway bars, weight reduction, frame stiffening etc. To see how the stock form of the car reacts to him sitting in it is worthless. As nothing can be done to correct it. There are no adjustments available.
Quick Reply: Would anyone be interested in some V1 weight information?
